Never a break, I sware
Old Dec 20, 2003 | 06:15 PM
Leonard's Avatar
OUCH!!!
it damned well better if it only lasted six months... :-/
Old Dec 20, 2003 | 07:40 PM
TheShow50h's Avatar
The little 5.0 that could
Wow, that really sucks man ... brand new tranny after 6 months and it was 4th gear? That's the gear it stuck in? Strange that would be the gear to go.
Damn man, probably not an option to get a tremec, huh?
-Vince
Old Dec 20, 2003 | 08:13 PM
TheShow50h's Avatar
Originally posted by Mars_302
acutally it started grinding 4th, then it got stuck in 3rd tonight, got it outta third, now its stuck in first. You can barely move the shifter even with the engine off.
Your really getting screwed over after breaking 2 t5s and a new t5z. Something isn't right.
Old Dec 21, 2003 | 03:19 AM
race495's Avatar
Pull Over
You sure you adjusted the stops correctly on the shifter? Sounds an awful lot like bent shift forks to me.
"I'm in the 82nd Airborne and this is as far as the bastards are going!"
93 Cobra, R302 331,canfields,T-76,TKO......sold
87 Coupe, 466, Edelbrock heads,Vic jr,150 shot 10.41@129.5...sold
2006 Honda 450ER .....new toy
Do you own a Torch Red FRC and tremble every time you drive under I75 on Hwy 60 and look in your rearview mirror? If so you are suffering from what is known as Cobraphobia.
Old Dec 21, 2003 | 04:50 AM
Strokd85's Avatar
Daddy-O
time for a tremec or G-force...
I am your penalty.....
Old Dec 21, 2003 | 05:35 AM
Matts50's Avatar
The Freak
He's not making nearly enough power for one of those trannys......I think he has a stock shifter on it too. Talk about bad luck.....
Matt
AIM- Wildcard302
Old Dec 21, 2003 | 06:41 AM
Strokd85's Avatar
Daddy-O
the trany's aren't just built for power, they're a better built transmission as well. You don't haveto have a minimum hosepower rating to use one.
new shifter will help, but is it the same problem on each one?
