Mod motor :^D
Hmmmmmmmmm...... Well lets see i was just reading the new MM&FF and i wanted 2 shoot myself.
OK why you ask
well i see this artical
about a heads cam swap on a 00GT auto.Ok well it makes 217 rwhp stock then they do the heads and cam the it makes 244.2 rwtq274. i was like whaaaaaaaaaaaaaaaaaat
picked up 27.2 rwhp. I was like damn that suck but wait then they put a bullit intake on it
then it goes up to 248 rwhp. so ok about 3K in mods and under 30rwhp gain wow Mod motor kick ass.but i didn't have all the boltons and it was a aod and it was a street set up but still for the prices of the parts and the gain i would have 2 hurt somthing.
OK why you ask
Yeah it's broken
-Cobra block
-Cobra crank
-Diamond pistons
-Eagle rods
-NOSzle Kit
-Bottle Heater
-QA1 K-Member
-D&D Tubular A-arms
-D&D Coil overs
-1/2' Intake spacer
-Windage tray
-80MM C&L
-K&N Filter
-FR Aluminum drive shaft
-Steeda G-trac bar
-Kenny Brown sub frames
-UPR shifter
-Spec clutch
-Spec Alumn Flywheel
-Steeda Clutch quadrant
-Steeda fire wall adj
-4:10 gear
-Mac upper adj control arms
-Mac Lower control arms
-Mac T/A girdle
-Steeda quad shocks
-Hooker long tubes
-DR.Gas X-pipe
Yeah it's broken-Cobra block
-Cobra crank
-Diamond pistons
-Eagle rods
-NOSzle Kit
-Bottle Heater
-QA1 K-Member
-D&D Tubular A-arms
-D&D Coil overs
-1/2' Intake spacer
-Windage tray
-80MM C&L
-K&N Filter
-Steeda G-trac bar
-UPR shifter
-Spec clutch
-4:10 gear
-Mac T/A girdle
-Steeda quad shocks
-Hooker long tubes
-DR.Gas X-pipe
well, the 99 up heads should be ported rather than replaced, and i'm sure a cam would pick up the power they are missing with the better intake and heads and no cam changes..........
200 points away from a 300
It is all in the package and tune. There are a few people at the modular depot forums who have gotten over 300 RWHP with no power adder. These motors will make power but have a high initial investment going at it N/A. Give it time for the aftermarket and machine shops to figure out what combinations are the best. I will keep my Mod Motor....
Member Modern Mustangs of North America
http://www.modernmustangs-na.com
Originally posted by rintin
BUT
BUT
OK why you ask
OK why you ask
btw, do the ford mags use a different dyno or something, because they had a new 5.0 in the new 5.0 mustangs mag and they had a free flowing exhaust, roller rockers, undrive pulleys, and an edelbrock intake, and they put a nice cam in, and only came out with 212hp. Sounds a bit low considering a stock one should be making 191. (with a 15% drivetrain loss)
-Vince
-Vince
ya i know, that's what im trying to say in a way. The mags must use different dynos because they dynoed a stock mach and it only made 248!!! at the wheels in a 5.0 mustangs article.
it's too bad there have to be so many different types of dynos, it confuses me.
-Vince
-Vince
