to lock or not to lock?
Originally posted by Strokd85
Do not do your burnout in the waterbox (if this is not what you meant Scott then ignore). Don't even pull through the water box with the DRs, with the tread all you will do is sling water into your wheel wells which will proceed to drip while you stage.
Solo.. I think he was more worried about his brakes, not thinking that this will give him better times...
Is it needed? no, but not a bad thing to have either.
I do indeed want to save brakes and no matter who I tell this to, they seem to misunderstand me.
It wears the pads and rotors everytime I powerbrake.
If I use a line lock, it no longer wears on the brakes at all.
thus I have saved some life in my rotors and pads.
It may only be a slight lil bit, but it is a savings over all in terms of my brakes.
So Dereck, u think I should just spin em up dry?
I mean I thought water would be ok, but I guess with D/R's they dont like water to much ?
let me know what exactly I should do for a burnout as I am not used to burnouts with D/R's...
Thanks again
Chris
Guest
Posts: n/a
I see where my response looked like it read to stay in the water for DR's but I meant to just stay in the gas a little longer a car out of the water box.
