MMX - Check Out our 392 HEMI Hi-RAM Performance Camshaft vs Stock on our Engine Dyno
Old Dec 13, 2023 | 07:50 AM
Default MMX - Check Out our 392 HEMI Hi-RAM Performance Camshaft vs Stock on our Engine Dyno
This is NOT a fake-o computer tweak!
MMX - Check Out our 392 HEMI Hi-RAM Performance Camshaft vs Stock on our Engine Dyno (+126 Horsepower Gain!!!) at MMX
Modern Muscle Xtreme From:sales@modernmusclextreme.com
odernMuscleXtreme.com MMX Shop Builds About Us sales@modernmusclextreme.com
Features:
  • HEMI VVT cam grind
  • PN - NA - MAX - EFFORT
  • INT @50-229
  • EXH @50-24x
  • Lift .615 Intake and Exhaust
  • LSA 111
625 Lift SPRINGS REQUIRED!
MMX's Hi-RAM 392 Camshaft
Our 6.4L 392 VVT HEMI Performance HI-RAM MAX EFFORT NA Camshaft is designed for the 6.4 Hemi Owner who wants max power on a stock bottom end 392!
This camshaft with Ported Heads, 105MM Throttle Body, Holley 105MM HI-Ram Intake Manifold, made 126HP Over stock on our Superflow Engine Dyno!
After years of Research and Development we are proud to release our all-new MMX HI-RAM 392 Max Effort Camshaft! This camshaft will squeeze as much power out of a stock piston 392 as possible! This camshaft is specifically made for short runner intake manifolds like the Holley Hi-Ram, Ritter Intake, Drag Pack Intake, Holley Single Plane, and Prefix Intake Manifolds. This new grind is made to take advantage and make max power out of the shorter runner length these manifolds provide. This camshaft works best with a 92-108MM Hellcat Style Throttle Body, Long Tube Headers, Holley Hi-Ram Intake Manifold, and CNC Ported Cylinder Heads. Our New Grind Makes Peak Power at 7000RPM and will stay flat until a few hundred RPM past that.
Due to the VERY tight confines of the stock bottom end 392, it is not recommended to mill heads or use a thinner than stock head gasket with this camshaft on the stock bottom end.
Aftermarket Higher Stall Converter Required for Maximum Performance.
Will require VVT Lock Kit and custom tuning. If an aftermarket piston with deeper valve relief's is used, you may use a limiter.
Call Today To Find Out More! 276.666.1934
Copyright © 2023 Modern Muscle Performance Group. All Rights Reserved. info@modernmuscleperformance.com
Old Dec 13, 2023 | 07:52 AM
Default learn what you love!
https://www.tamparacing.com/forums/c...dquarters.html
Jun 23, 2023 11:42 AM
American Iron Tech
Jan 17, 2020 08:20 PM
Drag Racing
Apr 15, 2019 09:41 PM
pstang
Jan 29, 2006 05:39 AM
Cronic
Apr 18, 2004 05:55 AM
