6.4L 392 VVT HEMI MAX EFFORT V2 NA Performance Camshaft by Modern Muscle Xtreme
Old Jun 23, 2023 | 11:42 AM
Default 6.4L 392 VVT HEMI MAX EFFORT V2 NA Performance Camshaft by Modern Muscle Xtreme
lextreme.com>Unsubscribe
Fri, Jun 23 at 12:13 PM www.ModernMuscleXtreme.com MMX Shop Builds About Us sales@modernmusclextreme.com6.4L 392 VVT HEMI MAX EFFORT V2 NA Performance Camshaft by Modern Muscle Xtreme
Our 6.4L 392 VVT HEMI Performance MAX EFFORT NA V2 camshaft is designed for the 6.4 Hemi Owner who wants max power on a stock bottom end 392!
This camshaft with full bolt on's typically makes +60-70 RWHP over the factory camshaft.
We have re-designed our ever-popular Max Effort 6.4 camshaft to squeeze as much power out of a stock piston 392 as possible! This camshaft will make 8-10 more peak HP, and even more low-end torque than our max effort camshaft. This new cam will also carry peak power out a few hundred RPM higher than our Max effort cam. This cam requires a 1320 stall converter at a minimum to prevent heavy "bucking" or surging at idle. This camshaft has a VERY aggressive idle sound!
Features:
• HEMI VVT cam grind
• PN - NA - MAX - EFFORT
• INT @50-22x
• EXH @50-23x
SPRINGS REQUIRED!
Will require VVT Lock Kit and custom tuning. Exhaust upgrades such as long tube headers, ported intake, and larger throttle body recommended for best results.
***IT IS HIGHLY RECOMMENDED TO DEGREE AND CHECK PISTON TO VALVE CLEARANCE WITH THIS CAMSHAFT*** Due to the tight confines of the stock bottom end 392, it is not recommended to mill heads or use a thinner than stock head gasket with this camshaft on the stock bottom end.
Call Today To Find Out More! 276.666.1934
Copyright © 2023 Modern Muscle Performance Group. All Rights Reserved. info@modernmuscleperformance.com
American Iron Tech
Nov 15, 2019 06:18 AM
Jan 9, 2019 05:16 AM
navin86
Car Audio For Sale
Apr 28, 2009 11:33 AM
sr24087
Drag Racing
Jan 25, 2007 11:58 AM
