AWD H&R springs lowering, spring compressor
Old Jun 16, 2019 | 11:32 PM
Default AWD H&R springs lowering, spring compressor
Originally Posted by codycat91
Hey guys, I've searched for a while and there's not a ton of info out there. Im looking for testimonials on anyone running the H&R 50881-4 lowering springs on a 2011-2014 Charger AWD. Looking for opinions on ride quality, look, and any issues or regrets. According to the H&R website, they drop the car 1.6" front and 1.4" rear without need for different shocks. Im looking for more of an upgrade handling-wise as opposed to looks, although the lowered look is okay too.
Also just confirming that I will need a spring compressor for the front only.
Thanks guys
https://fasthemis.com/i-23893338-hr-...2011-2019.html
Old Jun 16, 2019 | 11:33 PM
H&R is a respected brand.
With RWD, 1.5" drop is about right for the street...and it allows use of stock shocks.
Companies keep their spring rates to themselves, but the same spring rate as stock is hard enough unless you are getting airborn and need hard shocks to keep the airborn body from crashing onto the suspension.
Otherwise stock spring rates are designed to support the car. You are not running Baja and don't need hard springs.
17 year olds think hard shocks substitute for anti sway bars.
There are PAGES written about why anti-sway bars keep the car from leaning, and hard springs just beat up the car.....which is what another member is also saying in this thread.
If you are in FL, we can use my spring compressor.
Most autoparts stores rent or loan spring compressors.
If a spring has the shock bolt going verticle through the middle of the spring, (sometimes called a "coilover") get a spring compressor that will compress the OUTSIDE of the spring, otherwise the inside spring compressor will interfere with the shock bolt that goes up the middle of the spring and won't work.
Showtime33647
Apr 2, 2014 03:09 PM
luvsracin87
Jun 6, 2006 07:32 PM
freakasis
Oct 28, 2005 04:51 AM
japanbran
Aug 1, 2004 08:28 AM
ericmichael
Jan 18, 2004 09:48 PM
