ABS bleeding procedure
Old Mar 30, 2019 | 10:17 PM
Default ABS bleeding procedure
You just push the ignition switch to "run" with your foot OFF the brake pedal so that the engine doesn't start, this will turn the abs pump on. When all the dash lights go out push the ignition to "off" then bleed the passenger rear wheel 1st. Repeat the process doing the driver rear, repeat doing the pass front, and finally the driver front (longest brake line to shortest).
Bleed with Scan tool GM
22,494 views38 5 Share
SaveBYUI AutomotiveVideos
ShockerGT
Subaru Tech
4
Apr 25, 2009 08:31 AM
psychx
6
Oct 14, 2007 09:53 AM
B20.eg
Aug 15, 2007 04:37 AM
B20.eg
Sep 20, 2006 05:55 PM
Ian MMF
Aug 27, 2005 06:26 PM
