Installed Hellcat intake on scatpack today
Old Mar 28, 2019 | 08:06 PM
2019 Hellcat lower airbox tube install on Charger scat pack. Functional Grille inlet nostrils
Functional Grille! 2019 Hellcat air box install video
544 views15 0 Share
Save
NewKindPublished on Feb 6, 20192019 Hellcat lower airbox tube install on Charger scat pack. Functional Grille inlet nostrils
Old Mar 28, 2019 | 08:10 PM
Installing a factory Hellcat intake onto a Challenger R/T. Cheap to buy, easy to install.
2017 Dodge Challenger R/T Hellcat Intake Conversion
7,748 views128 3 Share
Save
R/T WaspPublished on Jun 18, 2017Installing a factory Hellcat intake onto a Challenger R/T. Cheap to buy, easy to install.
Old Mar 28, 2019 | 08:15 PM
I install a Hellcat Air Box in my '17 Challenger R/T aka Clementine.
Challenger Hellcat Air Box mod Install.
2,214 views51 5 Share
Save
Happy MusclePublished on Nov 19, 2017In Episode 12 I install a Hellcat Air Box in my '17 Challenger R/T aka Clementine.
Old Mar 30, 2019 | 11:49 PM
Default There are two designs of the radiator side shield
also there are two designs of the radiator side shield. One like pictured above by krautmster pre 2019 and the 2019 design attached belowAttached Thumbnails
Old Mar 30, 2019 | 11:50 PM
That is what the "radiator side shield" does for you...you remove the stock piece and install the one with the opening in its place.Attached Thumbnails
Old Mar 30, 2019 | 11:52 PM
The scat packs have the opening in the grill, but there is a shield that goes beside the radiator that on the scat pack is closed off. For the hellcat it has an opening. That also needs to be replaced. The link provided above has the radiator shield, the duct/tube and the lower air box. All you would then need is the hellcat air filter.Attached Thumbnails
Old Mar 30, 2019 | 11:56 PM
  #17 (permalink)
Pull the rubber plug out of the front, insert tube:Attached Thumbnails
Gixxer
Aug 20, 2007 06:40 PM
Rotary7
Mazda Tech
13
Feb 25, 2006 06:53 PM
chet
Feb 26, 2004 06:52 PM
Tiburon
Jun 17, 2003 01:08 PM
