2013 pursuit battery drain.
Old Feb 24, 2019 | 09:54 PM
Originally Posted by mroberge82
Yah Im dead in the water today, we have 40-60mph winds and a blizzard warning. But as I mentioned before Im not to good at electrical stuff I ended up finding my multi meter had a blown small fuse and a ton of corrosion on one of the post for its aaa batteries. woops small oversite. When weather permits ill start over with it in a series and pull fuses again. Thanks so far for the help though this has been great.
You are getting closer to resolution. I'd use the negative to amp side of the meter. You are looking for a amp or so draw, and the risk of blowing the little fuse again is high. Don't let the battery die or leave it dead - especially if it's freezing out. It will become useless. Put a trickle charger on it - $20 at walmart - until you can work on it.
Old Feb 24, 2019 | 09:55 PM
While I'm tracking a battery drain problem, I had put in a battery cut off switch....While I'm tracking a battery drain problem, I had put in a battery cut off switch,
so when I park it at night, I kill the power to avoid draining.......it also is considered anti-theft and gets an insurance discount.
Don't cost much at Harbor Freight.
The knife switch costs more over the i-net, but is more reliable as to making good contact.
Feb 26, 2019 09:40 PM
Feb 26, 2019 09:36 PM
4
Jan 31, 2019 12:20 AM
Drag Racing
4
Jun 2, 2018 10:50 PM
