Stereo Noise While Car Is Started
Old Feb 13, 2019 | 02:16 AM
Default Stereo Noise While Car Is Started
AKCallahan
Senior Member
Stereo Noise While Car Is StartedI’ve noticed recently that there’s a whining stereo noise in the audio, even when paused on USB or muted on FM, that changes pitch with acceleration. No changes have been made to the audio system in years. I’ve read it is usually a faulty ground for the head or amp. How can I confirm and fix the issue ASAP? Thank you!
Old Feb 13, 2019 | 02:17 AM
back in the "day" a whine in the radio that increased with rpm was caused by bad spark plugs or spark plug wires... Have you recently done any work in that area?
2016 SXT PLUS
Ivory Tri-Coat Pearl
No spark plug wires........
OP, as you said nowadays it's usually a ground problem. I'd start with the engine grounds.
Old Feb 13, 2019 | 02:18 AM
Engine grounds are good. Called a shop I took my truck to a couple of months ago and he confirmed what I had read on google where when the head unit becomes less grounded than it should, it seeks a ground through all avenues like speakers and even the antenna. He opted to have me check the grounding on the rear of the unit then if that isn’t the problem, look into installing an ground loop isolator.
Old Feb 13, 2019 | 02:19 AM
Basically correct. The whine is likely characteristic of the DC ripple in the output of the alternator. If it's a single package head unit - radion and amp in one box - a bit of ripple in the DC shouldn't make a whine. If the amp is separate from the head, then it's possible that the audio lines from the head in the dash to the amp - probably in the trunk - can pick up the voltage difference between the front and rear of the car, including any AC ripple.
Please clarify if one or two piece.
If the car has an antenne where the other end of the coax is attached to the car ground - satellite or stick FM / AM antenna - or maybe any kind if antenna, the shield is grounded at back of car - that could cause a ground differential. Speakers are not likely because they are balanced - two wires never touching ground - from the amp output (in the radio head or external amp) to the speakers.
Easy to prove it's alternator. Disconnect the field connector on the alternator. Car will give warning on dash because no charge. See if noise is still present. You may now hear different noise from injectors or spark plugs. Stop engine and hook alternator back up.
You should be able to track this down. You'll need a multimeter. With engine running... Set it to the most sensitive AC - not DC - mode. Ripple (whine) is AC. Start across battery terminals. Should be virtually no - a few millivolts - of AC. If significant, then maybe battery high impedance - or even maybe open diode in alternator. You'd need a scope to prove that.
Then, one meter lead on negative terminal, touch other meter lead to car body, engine, etc getting progressively further away from battery. If you see higher ripple, then likely it's a bad connection somewhere.
This may be a bit complicated, but if you can get the idea, it may be a bit clear.
Feb 26, 2019 09:36 PM
Feb 26, 2019 09:33 PM
11
Feb 24, 2019 09:55 PM
4
Jan 31, 2019 12:20 AM
Drag Racing
4
Jun 2, 2018 10:50 PM
