$100 car update
Old Oct 18, 2002 | 02:16 PM
  #41 (permalink)
CrazyMoparGirl's Avatar
Guest
cool
Old Oct 25, 2002 | 09:32 AM
  #42 (permalink)
4sfed 4's Avatar
4SFED4
Originally posted by "whore"
one thing about intercooling that car.. shadows cant use the daytona/lebaron IC/Rad setup which is the most common. You COULD fab some mounts and use it, but its no bolt in.
Put the g-valve on and set it to 15psi or even the same as its at now. The computer can handle up to 15 (where the cutout is). Even at stock boost, it spools SOOO much quicker. Well, actually.. you have a Mitsy turbo so it wont be a HUGE diff, but still noticable im sure
Just make sure the IC is on at 15 psi boost!
15 psi without the IC is risky business!
Heres what my T1 non intercooled headgasket looked like after 15 psi with no IC
Old Oct 25, 2002 | 11:05 AM
  #43 (permalink)
whore's Avatar
pwned!
Damn larry, i'm really getting fed up with this car. I cant even get to setting the fuel curve between everything else going wrong on it. I just had to get the turbo rebuilt. Tell me the secret to adjusting the base FP and the Cartech!!
Old Oct 25, 2002 | 12:40 PM
  #44 (permalink)
4sfed 4's Avatar
4SFED4
pwned!
Go to the dyno!
With the wideband O2 sensor on the dyno, you wont have to guess at whats going on.
The Cartech is very sensitive!
What happened to the turbo?
Larry
2002 MB C320 Sport Wagon 15.4@91
2002 Dodge Neon SE
1991 Dodge Spirit R/T-12.3@117 (at 368 whp) Now 500 whp / 514 ft lb on pump gas
Old Oct 25, 2002 | 06:44 PM
  #45 (permalink)
whore's Avatar
after all the month of crap with making that head work, the turbo decided to go south. Brought it to CMR to get built, the oil seal had a lot of wear on one side, and the bearings had some debris go thru them. He also found a wrong piece in the exhaust side which was causing exhaust to bypass the turbine = wasted power. All is well now, its back on the car.
Old Oct 25, 2002 | 10:37 PM
  #46 (permalink)
Guest
I guess I got lucky w/ my head gasket. I spiked 20 psi on my old T1.
Old Oct 26, 2002 | 08:57 AM
  #47 (permalink)
4sfed 4's Avatar
4SFED4
Awww...that stinks. Some garbage must have gotten into the oil with all the other stuff going on.
As far as a wrong piece on the exhaust side.....what could that have been? The only thing that allows exhaust gas to bypass is the wastegate hole / flapper. Is he saying the flapper was not sealing?
Larry
2002 Dodge Neon SE
Old Oct 26, 2002 | 08:58 AM
  #48 (permalink)
4sfed 4's Avatar
4SFED4
When I blew the headgasket in the phot above, it wasnt a spike. It was steady state WOT boost!
Larry
2002 Dodge Neon SE
