Problem Solved!
Guest
Posts: n/a
easy close the vavles, compressed air will hold them up or put a bunch of string or small diameter rop and turn the engine over by hand slowly till it stops. The rope will also hold the vavles shut. Sears should have a valve spring compressor not sure if it will work on a 2.2 however. Might not be enough room around the spring
If not John has a spring compressor that bolts onto the head, you still need to use air or something to hold the valve up. If your just gonna swap the one see if he will let you borrow it. Or I can tow your ass up there and you can do it there.
