Problem Solved!
Old Jul 27, 2002 | 06:13 PM
  #22 (permalink)
mpbiv's Avatar
Rod Bearing Eater
Well J3ff If that didn't fix it, then what could it have been. You shoulda started it and took a test drive, don't be such a pessimist.
Oh BTW If I can get this damn car fixed, I really wanna make a trip to get some CDM parts. I was thinking I don't need a truck (or have one) as long as I remove the back seat, I can put an engine there
Patrick
05 SRT-4: Daily Driver, 11.9@117.4
88 Aries: 2.2L Turbo (Powered by Megasquirt II)
Old Jul 27, 2002 | 07:27 PM
  #23 (permalink)
CrazyMoparGirl's Avatar
Guest
actually the engine will fit in the trunk, not that I've done that or anything.
Old Jul 27, 2002 | 07:46 PM
  #24 (permalink)
mpbiv's Avatar
Rod Bearing Eater
Yeah but I have to be able to cruise down the turnpike at 85mph with the trunk closed
Now that I think of it you are probably right. of course I would have to tilt it over to fit it in. Plus I would have to lift it to clear, and quite frankly I don't want to spend more money to repair the rear end again.
Other option was to split it into several parts: 1)head, intake, exhaust and turbo 2) block.
All scrapyards have to drain the fluids before they put the car in the yard right?
I am gonna go with transporting it in the car in several pieces. I know I can have it apart lickity split.......................I hope
Patrick
Old Jul 27, 2002 | 08:23 PM
  #25 (permalink)
leadfootedfool's Avatar
Eat soot
I've seen some pretty nasty crap come out of the engines, not to mention the puddles around the yard on a hot dry day with no rain in site.
Old Jul 27, 2002 | 08:56 PM
  #26 (permalink)
mpbiv's Avatar
Rod Bearing Eater
Well in that case I won't mind draining it straight into their yard
Patrick
Old Jul 27, 2002 | 09:01 PM
  #27 (permalink)
mpbiv's Avatar
Rod Bearing Eater
What about Cophers specifically? Over here they don't usually let me walk around the yards, or pull my own stuff. Its a bitch cause I have to ask them if they have something and usually they say they don't because they dick at the counter doesn't want to spend time to look it up.
I went to one yard and asked if he had any chrysler turbo engines and he said no, but there was a leabron quarter panel sitting right there at the counter that had a turbo badge on it. However the guy just kept saying "we don't have terbos" in some unknown accent.
Patrick
Old Jul 27, 2002 | 09:09 PM
  #28 (permalink)
Eat soot
I was talking about cophers.....just don't kick any bottles, step in any puddles, or play in the yellow dirt.
Old Jul 27, 2002 | 09:11 PM
  #29 (permalink)
mpbiv's Avatar
Rod Bearing Eater
thanks for the tip
Patrick
Old Jul 27, 2002 | 09:30 PM
  #30 (permalink)
Guest
every Cophers I've been in they let you walk around and pull your own parts, just have to pay $1 and sign the waiver. Copher Bros. does not let you walk in back. BTW Ford owns Cophers so that may explain their mentality. What am I saying may, of course it explains it 100%
