Problem Solved!
Old Jul 25, 2002 | 06:19 PM
highoctane's Avatar
If you rotate the engine so that the piston is at the top of the stroke the valve won't fall into the cylinder.
All you need is a stick, screwdriver, or something to stick in the spark plug hole, rotate the crank until you see the screwdriver at it's highest point.
The furthest the valve will fall is to the top of the piston which usually isn't very far at all, and depending on the type of valve seals your head uses they usually put enough tension on the valve stem to keep them from just falling in as well.
One of the hardest things is trying to keep the two small valve spring retainer locks from falling into the engine, a good magnet on them while compressing the spring works nicely, blocking holes in the immediate area is a good precation as well.
