1st gen neon setup
Old Apr 25, 2005 | 11:52 AM
  #31 (permalink)
Josiah's Avatar
Peon on steroids!
nope...I may spend $5000 on my engine...but I'm too cheap to buy a digital camera....have some undeveloped pictures of the engine build...thats about it
Old Apr 28, 2005 | 06:01 PM
  #32 (permalink)
GsEclipse02's Avatar
there both 420a motors so i thought i would try .... i want to get rid of my down pipe manifold and intercooler piping give me a decent offer on the sub and it will be yours...
Old Apr 28, 2005 | 06:56 PM
  #33 (permalink)
Josiah's Avatar
Peon on steroids!
actually the neon is not a 420a motor....similar but not the same,
Old Apr 28, 2005 | 07:07 PM
  #34 (permalink)
neondriver's Avatar
D4RE Correct?
Old Apr 29, 2005 | 04:38 PM
  #35 (permalink)
Josiah's Avatar
Peon on steroids!
some weird ass code, I know my 2.4 is a KZE...if I remember correctly, the neon is D4RE for DOHC 2.0 and S4RE for SOHC
Old May 6, 2005 | 12:46 PM
  #36 (permalink)
neondriver's Avatar
whenever you redo the pipes let me know and ill take the old ones, ive been seeing people using the srt intercooler but i didnt want to cut up my car.i finally got my car from the paint shop and put in a new system so now im focused on the turbo kit, i spent a little time puting together some of the fuel items.
how do you think these look?
i have a braided line going from the fuel rail to rrfpr and then a rubber line going into a 100psi gauge then finally into a stock fed line that i got from the junkyard to use as my return line, i still need to install the mustang 24lb injectors. than when everything is ready i will add my gastank with a venom pump, hopefully when that is all done the turbo instal will begin.
Old May 6, 2005 | 02:54 PM
  #37 (permalink)
Josiah's Avatar
Peon on steroids!
looks pretty much like my seteup, but I use a MegaSquirt rather than the cartech for fuel control...used to have the chill factory unit...worked great but I got scared by the fuel pressure I would need to run 25psi, swapped to an aermotive 1:1, but I'm using a stock feed line for return as well, 4an from fuel rail to aeromotive, then 4an hose barb to fuel injection line running back to the return line. I like the johnny racecar I/C but want to shorten my piping a bit(and redo it out of aluminum if I can)
Old May 6, 2005 | 04:06 PM
  #38 (permalink)
cali's Avatar
Skittle on crack!
What fuel pressure are u running? I have been told those quick connects are SAFELY rated for 75PSI....above that user beware.
You can quit watching me now....
Old May 6, 2005 | 05:41 PM
  #39 (permalink)
Josiah's Avatar
Peon on steroids!
i was running 80+ on mine...but mine was just clamped onto the return line with a fuel hose clamp...not that I run that high anymore, I didnt like insane fuel pressures, which is why I got the megasquirt
Old May 6, 2005 | 05:52 PM
  #40 (permalink)
cali's Avatar
Skittle on crack!
neither me...thats part of the reason why I ran away from a rtn line
