Chassis & Suspension Tech Cages, braces, suspension set up and more
solid axle rear suspension
Old Oct 30, 2025 | 11:25 PM
Default solid axle rear suspension
"Suspended" Decisions
By Mark Simpson
Let’s face it—not all cars have perfect suspension. Personally, I do my best to keep a classic car 100% original, but putting hundreds of thousands of miles on a car built in the 30s or 40s can reveal some areas that need desperate attention. In a word: suspension. Even cars built in the 80s and later can benefit from suspension improvements. For enthusiasts who choose to modify or update their suspension, it’s important to make the right decisions for your classic car.
Building or modifying a street rod often requires numerous decisions based on performance needs, intended use, and budget constraints. When it comes to rear suspension, there are numerous options that should be considered to keep your project firmly planted on the ground and headed in the right direction.
Years ago, when I first started my ’35 Chevrolet project, I knew I wanted a low stance and a smooth, but relatively traditional, street rod look. I chose to utilize the original rear leaf springs, in part to keep the project within my established budget. After the narrowed ten-bolt Chevy rear axle was in place, it was apparent that additional work was necessary to get the lowered stance I desired. To accomplish this, I had the rear springs de-arched four inches and built a set of 5/8-inch offset two-inch lowering blocks.
This gave me the low ride I desired, but allowed for plenty of suspension travel. After completing my ride and getting out on the road for the first time, I discovered I had significantly compromised the load capacity of the rear springs, and with passengers in the rear, the car was prone to bottoming out. While not ideal, a set of coil-over shocks with lightweight progressive springs alleviated the problem until I was ready to return to the shop and reengineer the rear suspension.
After blowing a head gasket a few years ago, I took the opportunity to revisit my entire driveline before putting the old bowtie back on the road. The 400ci small block engine gave way to a far more potent GM Performance Parts 383 engine, and the tired TH400 transmission was soon replaced by a bulletproof Gearstar 4L60, giving me the overdrive I desired. Soon my attention was squarely focused on the rear axle and suspension, which I knew would be the weak link in the system.
When considering the options for rear suspension systems (see below), I soon focused on two options: triangulated four-bar and parallel four-bar. A call to the folks at Art Morrison Enterprises soon set me in the right direction.
Old Oct 30, 2025 | 11:30 PM
Default part 2 axles
The triangulated four-bar systems do not require a Panhard bar to laterally locate the rear axle (although in tight street rod applications, routing exhaust can become far more difficult). Art Morrison also pointed out that for optimal operation, they should not be used on frames narrower than 39 inches. Also, throughout their use, the pinion angle can change slightly as the two sets of suspension arms travel on different axis.
The parallel four-bar systems do require an additional Panhard bar to firmly locate the rear suspension side-to-side, but offer greater clearance for exhaust. This system maintains the same pinion angle throughout its full travel and is strongly recommended for lowered and air-suspended cars and trucks. The installation for these systems is fairly straightforward and was right on target for our project.
Upgrading the rear axle brought back memories of searching junkyards, swap meets, and local classifieds for a rear axle that would fit beneath the car with the wheels I wanted. It always seemed that compromises had to be made simply to make it work. Thankfully, those days are long gone, and ordering a custom-made nine-inch Ford rear axle with Explorer disc brakes and a 3.50:1 Positraction differential that perfectly fits our application is a painless process, thanks to the folks at Currie Enterprises. The quality of their rear-end assemblies and seemingly limitless options made this an easy choice for our new system.
Follow along as I share some of the insights I gained on this project and put my ’35 Chevy back on the road.
Old Oct 30, 2025 | 11:37 PM
Default part 4 axles
This is really part 3
Old Oct 30, 2025 | 11:42 PM
Default part 4 axle
Old Oct 30, 2025 | 11:45 PM
Default part 5 axles
Old Oct 30, 2025 | 11:49 PM
Default part 6 axles
Default part 7 axles
Sep 1, 2018 12:22 AM
_Charles_
Dec 24, 2008 11:51 AM
j0shth3j3w
For Sale/WTB Honda & Acura
Sep 20, 2008 05:28 PM
BeQuietAndDrive
Jul 15, 2005 11:43 PM
Jesse850GLT
Drag Racing
Feb 5, 2004 12:34 AM
