Strut questions I've been having the clunking issue and found it to be the struts. I
Strut questionsI've been having the clunking issue and found it to be the struts. I'm new to anything having to do with performance suspension so I was just wondering what would be a good setup? I'd like to upgrade from stock but not sure where to start. I'm not ballin outta control so I'm not looking for the best possible option, just something that will make for a smoother ride. Could I just replace the struts, or should I replace the shocks too? Also, if I replace the front, should I also do the back? Not having any problems in the rear, just not sure if I should have matching setups in the front and rear. I'm sure there will be more questions to come, I just can't think of anymore right now lol.
Thanks
Thanks
Sorry, should've known to add those details. It's an 06 R/T with 120,000 miles. No special packages
Sent from my SM-G965U using Tapatalk
It's probably safe to assume they have enough miles on them that the ride would benefit from new replacements. So starting there, you could replace just the front struts and get a much improved ride out of it. Adding in rear shocks to that would be best but not absolutely necessary. Replacing all 4 shocks and struts would yield the best improvement in ride quality obviously.
As far as performance upgrades go, you can get some benefit from going with the performance versions of whatever shocks/struts you buy, but it won't be a lot. In order to get a true performance suspension feel, you would need to also replace the coil springs and anti-sway bars too. Replacing the springs with some SRT springs would yield an improved suspension akin to a performance upgrade, but it will also lower the car an inch or so. So that should be kept in mind.
Also, you could do the strut assemblies, shocks, and coil springs with performance alternatives and not do the anti-sway bars, but it would be best to include them. The main reason to not include them would be the labor involved to replace them. The front anti-sway bar isn't terrible to replace, but the rear one requires dropping the entire cradle, which can be a pain if you're doing it in your garage with only jack stands and a floor jack at your disposal.
FYI: if you really want to know if they are the OE shocks/struts, jack it up and pull the wheel and see if you can see the brand name on the body of the shock/strut. If it says Sachs, they are either the original ones or OEM replacements (my money would be on them being the originals, as not many people go with OEM when replacing the shocks/struts unless they’re the performance kind).
Sep 18, 2018 12:52 AM
