Chassis & Suspension Tech Cages, braces, suspension set up and more
I was a cheating S.O.B in vintage class if I had read the rule book, F.U.
Old Jun 22, 2025 | 10:30 AM
Default I was a cheating S.O.B in vintage class if I had read the rule book, F.U.
wspohn
wspohn UltraDork
2/3/25 10:44 a.m.
I was a cheating S.O.B in vintage class if I had read the rule book, F.U..
Otherwise I could claim "I don't know a thing about it!"
Why did they call me Dork?
I ran in a vintage class that banned the addition of any added air passages. After thinking about it a bit, I just installed longer pins for the rear bonnet attachments of my MG, with two holes drilled for the retaining pins.
Going through tech? Just put the pins through the lower holes and sail through with no issues.
Before going out on the track to race, put the pins in the upper holes - still looks right to any scrutineers watching you go out on the track. Then on the track at speed, the rear of the bonnet lifts with the air pressure underneath and exposes a nice fat slice of exit space for the air that wants out from under it. Worked well and dropped under bonnet temps quite a few degrees.
My other aero trick was inspired by the rules failing to specify any minimum ground clearance for front air dams/spoilers. I made up a lower air dam section out of canvas/rubber conveyor belt material - it could actually touch the pavement under maximum braking but being flexible was quite long lasting. By having the air dam closer to the track surface I picked up about 500 rpm at the end of the straight
And possibly may rot in hell with all the other cheating S.O.B. racers.
Apr 11, 2023 05:46 PM
Frankie Figs
Dec 15, 2008 06:08 AM
limegreenneon
The Ford Forum Lounge
Apr 23, 2008 06:54 PM
jdr_racer
Aug 31, 2006 05:24 AM
bitemark46
Drag Racing
8
Nov 23, 2003 03:56 PM
