Bike Differance
GSX 750 F Katana 1999
Length: 2 135 mm (84.1 in)
Width: 750 mm (29.5 in)
Height: 1 190 mm (46.9 in)
Seat Height: 790 mm (31.1 in)
Wheelbase: 1 465 mm (57.7 in)
Ground Clearance: 120 mm (4.7 in)
Dry Weight: 200 kg (441 lbs)
Engine type: 748 cc, four-stroke, 4-cylinder, 16 valves, air/oil-cooled, DOHC,TSCC. 92,6 hp (68,1 Nm)/ 10,500 rpm, 66,7 Nm/ 9,500 rpm.
GSX-R 750 1999
Overall Length: 2 065 mm (81.3 in)
Overall Width: 720 mm (28.3 i.)
Overall Height: 1 165 mm (45.9 in)
Seat Height: 830 mm (32.7 in)
Wheelbase: 1 395 mm (54.9 in)
Ground Clearance: 130 mm (5.1 in)
Dry Weight: 179 kg (394 lbs)
Engine type: Water-cooled 749 cc inline-4, DOHC, 16 valves. 134 hp (97,8 kW)/ 12,000 rpm, 82 Nm/ 10.300 rpm.
Hope this helps,
~James
Originally Posted by JustMiata
It's like this: The toadstool juice fires through the unicorn injector into the fairy dust chamber, where the tiny wizard does his secret work...Then a gang of keebler elves get hopped up on the crystalline byproduct of the wizard's tinkering, (they smoke it) and then the elves push the spinning triangle through a series of dimensional portals to a final realm codenamed the "exhaust port..." At least that's my undersanding of rotary sorcery...
...Or
GSX 600 F Katana 1999
Length: 2 135 mm (84,1 in)
Width: 745 mm (29,3 in)
Height: 1 195 mm (47,0 in)
Seat Height: 785 mm (30,9 in)
Wheelbase: 1 470 mm (57,9 in)
Dry Weight: 202 kg (445,3 lbs)
Engine type: Air/oil-cooled 599 cc inline-4, DOHC, 16 valves. 86 hp (62,8 Nm)/ 10,500 rpm, 58 Nm (5,9 kg-m)/ 9,500 rpm.
GSX-R 600 1999
Overall Width: 720 mm (28.3 in)
Wheelbase: 1 390 mm (54.7 in)
Dry Weight: 174 kg (383 lbs)
Engine type: Water-cooled 600 cc inline-4, DOHC, 16 valves. 110 hp (80,9 kW)/ 11.800 rpm, 67,6 Nm / 10,000 rpm.
I just noticed that you didnt mention anything about displacment,
~James
GSX-R 600 1999
~James
Originally posted by chode
One is ugly, heavy, and slow while the other has a banana seat and says katana on the side.
"Ricey Hot Stuntaz" member #001
www.seductivecycles.com
Originally posted by Leslie
Katana's are definitely better looking.....just not a fast.
sorry can you tell i have one and im in love with it. but opinions are like a!@holes, everyones got one.Last edited by 11lovemygixxer; May 1, 2004 at 08:49 AM.
and i don't even like gixxer's that much
and i'm pretty sure the GSX-R's have a different frame, and i know the suspension is much better than a kitana
and thinks it's really funny when her nose goes bloody
'cause the blow is so yummy and it keeps her tummy empty
and makes her act more friendly
