Any Competitions Coming Up?
Going off of RMS power is the true fair way because if my amp is rated at 1500 RMS then it is pretty close to any other amp doing 1500 RMS
(RMS is a mathematical formula which is pretty hard to fudge or lie about).
If one guy runs his amp below the recomended and rated impedience level and gets more power out of it then if he doesn't cook it good for him but that is not the only thing involved in making an SPL meter move
The classes are broke down with the consumer in mind and to try and make it as fair as possible between the competitors in the same classes.
1. A walmart Visonik 1200 watt amp is not going to put out even close to my underrated sundown 1000 watt amp putting out almost 1500 watts.
2. As mentioned by the727kid, his sundown amp putting out 3000 @ 1 ohm (rated), will put out around ~3500 + @ .5 ohm
3. Some amps RMS are rated at 17.0 volts (ma audio) and some at 12.8 volts (sundown).
It's hard to find a perfect way to classify systems. One setup is always going to have an advantage over another depending on the classifaction scheme. Nonetheless, the show will be fun.
Car: 2000 Toyota 4Runner
Head unit: Kenwood eXcelon DNX8120
Components: Boston Acoustic Z6's
Components Amp: Kicker zx850.4
Subwoofers: (2) 15" FI BL's
Subwoofers Amps: (2) Kicker zx1500.1's
Wiring: Knuconceptz (4 Runs of 0/1, (2 pos, 2 neg)
Sound Deadening: Raamat (125 sq ft)
Batteries: Kinetic HC1800; 2 Kinetic HC2400's
HO Alternator: Mean Green ~220 Amp
149.2 db's on TL, sealed, at the dash, bassrace
Going off RMS power is not a very fair way to classify people's classes. RMS is lied about constantly by manufacturers. Here a few examples showing that this classifaction is not fair:
I think that if I were to run a show based on fuse size, A) I'd issue the fuses to prevent tampering B) I'd use an average SPL over like 5 seconds, to make sure we accurately see the time / current aspect of said fuse and C) deduct DB if the fuse is blown.
I guess there will always be ways to cheat, though.
Toby
We have 115 trophies to be given out at this show about half in the car show and half in the audio competition.
There are 1st, 2nd and 3rd place trophies for every class.
So chances are almost everybody that enters will win some kind of trophy and hopefully have fun.
If you are not sure about how to figure out which class you will be in come any way and you will be helped out by one of the judges at the show.
The show is this Sunday so come on out have fun and take home a trophy if you can.
Well I won't be able to make the show, I have to work until 530 =(.
Need anything installed or built? PM me.
MECP Certified.
Alarm: Viper 5200
HU: Stock
Active Set-Up
Tweets: Image Dyamics CD1pro mini horns
Mids: Sundown Neo Pro 8s
Amp: Kicker IX500.4 (2)
Sub Stage
Subs: (2) Dayton Audio 15" HF
Amp: Kicker IX1000.1
MECP Certified.
Alarm: Viper 5200
HU: Stock
Active Set-Up
Sub Stage
No trophy for you, to bad maybe you will catch the next one .
We weill continue posting for other shows we here about so everyone has the chance to check them out if they want.
We have been pretty active with two different leagues this year so we will keep everyone posted
Yea I know... I'm almost positive my car would walk out with 1st place in the car show for its class.
MECP Certified.
Alarm: Viper 5200
HU: Stock
Active Set-Up
Sub Stage
MECP Certified.
Alarm: Viper 5200
HU: Stock
Active Set-Up
Sub Stage
