Caddy Re-Build
I would make them any color other than red. Red always means postive to me, and most other people in the world. If that's all you have, get some expandable sleeving, or something, and cover them.
Also, do you have a lockwasher on the connection at the frame? If not, get one. If so, that means its around the back side...move it to the side you can see easily...makes it much simpler to see if its tight when you check on it periodically. I'd go bolt head---lock washer---flat washer---terminal---frame---flat washer---lock washer---nut.
If that's a factory bolt, or otherwise goes into something threaded, then you just need to add a lockwasher to the side you can see.
Toby
Toby
And also quick change I did real quick.. where there is a will, there is a way
Looks alot better imo.
Need anything installed or built? PM me.
MECP Certified.
Alarm: Viper 5200
HU: Stock
Active Set-Up
Tweets: Image Dyamics CD1pro mini horns
Mids: Sundown Neo Pro 8s
Amp: Kicker IX500.4 (2)
Sub Stage
Subs: (2) Dayton Audio 15" HF
Amp: Kicker IX1000.1
MECP Certified.
Alarm: Viper 5200
HU: Stock
Active Set-Up
Sub Stage
Got a chance to hook up the 100.4 today... only with one horn. Wow. This thing is LOUD and only has one horn, and I finally got the mid-bass out the Germs I've been looking for. Active FTW
MECP Certified.
Alarm: Viper 5200
HU: Stock
Active Set-Up
Sub Stage
MECP Certified.
Alarm: Viper 5200
HU: Stock
Active Set-Up
Sub Stage
What ya'll think, option A or obtion B? Excuse the wiring mess it still needs to be cleaned.
God both those pics came out bad..
MECP Certified.
Alarm: Viper 5200
HU: Stock
Active Set-Up
Sub Stage
MECP Certified.
Alarm: Viper 5200
HU: Stock
Active Set-Up
Sub Stage
looking good
New sig. coming soon
Code 52 VTAK On A Switch
MCOR Automotive LLC
http://www.mcorautomotive.com/
PM MCOR for any electronics, upholstrey, accessories or window tint (813) 362-5454
They will take care of you as they did me
MCOR Automotive LLC
rep given. just a question, why not aim the port to the rear deck and force the spl thru? thats how my grand marquis box was with a single ten hittin 138's on Ed easons termpro.. looks good tho.
also is sundown manfactured in the same plant as earthquake.. kinda looks like a quake amp.
oh yeah the nicest wire i have ever worked with was kicker... 4 gauge and 0 gauge that was supple and flexible.. with a really nice silicone jacket.... mmmm.. also it was matte finish.. sweet stuff
With the port up, in order to make it work correctly the port needs to flow perfectly into the cut out and the rear deck needs to be sealed off, more work than I feel like doing.
MECP Certified.
Alarm: Viper 5200
HU: Stock
Active Set-Up
Sub Stage
MECP Certified.
Alarm: Viper 5200
HU: Stock
Active Set-Up
Sub Stage
+1 if you don't seal the port you lose a lot of power to cancellation
Some more pics.... just about finished just want to clean it up any more... any tips/ideas?
MECP Certified.
Alarm: Viper 5200
HU: Stock
Active Set-Up
Sub Stage
MECP Certified.
Alarm: Viper 5200
HU: Stock
Active Set-Up
Sub Stage
