in dash dvd (help)!!!
Old Sep 25, 2006 | 03:42 PM
Notladstyle's Avatar
King of Ricers
Originally Posted by italiancorolla
I Used TOGGLE SWITCH SO YOU CAN DO EITHER ONE!!!!!!
SOUNDS LIKE IF HIS USES A GROUND TO TURN ON THE GROUND IS NOT GOOD ENOUGH
no its not that, the jensen 94xx are timing sensitive, a momentary switch with a short push, long push will disable the video bypass every time without fail.
notladstyle.blogspot.com
Old Sep 25, 2006 | 06:36 PM
TBSpyder's Avatar
Most of the Pioneers are different....they don't even need a switch. Just ground the green and you're done.
Old Sep 25, 2006 | 06:51 PM
pwilliedang's Avatar
how can i bypass with a kenwood in dash
Old Sep 25, 2006 | 06:54 PM
italiancorolla's Avatar
you know how you connect a wire to your e-brake... well instead hook it to a swtitch and then to a ground
Old Sep 25, 2006 | 06:55 PM
u mean the ground wire from the harness...hook it to a toggle switch and then from there another wire to the metal ground
Old Sep 26, 2006 | 04:58 AM
no, there should be a wire you hook to your e-brake.......then again I have a pioneer and I am hearing they are easier to bypass
Old Sep 26, 2006 | 06:00 PM
  #17 (permalink)
stompy's Avatar
ok as for the jensen all the new ones (e.g. xx11)
a toggle switch is fine you just need to time it right turn on wait about 2-3 sec, then off wait about 2-3 sec, then on.
a momentary push button will work a little easier but electricity realy doent care what type of switch it goes through. most pioneers are the same.
BTW i have installed several of these and have gotton all of them to work.
