audio ???
i unhooked the 4ch so only the 2ch is hooked up and bridged to the sub but it is still makin the engine whine so i dk because i am using the same wires i used in my old setup only thing that changed is the amp and sub but my old setup wasnt as strong as this and my old subs were in a bandpass box where this one is in a sealed.
.. you mean the amp/amp wiring is to blame right?
ya so i unplugged the rca and that stopped the whine so that would mean that something with my deck isnt working right? i used a voltmeter to check the ground in the stereo and it said it was fine?
A voltmeter cant check the ground - but if the noise stopped when you unplugged the RCAs you have already isolated the problem to either the headunit or the RCA cables themselves.
First, buy a new set of good quality RCAs. Run it on the opposite side of the car of the power cable and do not run parallel to the ground/power cable for more than 6 inches before it meets the amp.
one word --------------------------------- ground!
reground amp - upgrade ground on battery - check grounds on engine to frame, run new ground for head unit - double check the ground on the antenna - anything to do with ground check it - upgrade it .....
Pirate Customs
Sound, Security & Style..... anything for your ride
Pirate Customs
