audio ???
Old Sep 2, 2006 | 07:35 PM
hondadriver's Avatar
Default audio ???
ok so i have 2 amps that i am currently installing. one is a 4 ch. and has 2 inputs and one output the other is a 2 ch. bridged to a sub with one input. my head unit only has 2 outputs so how should i wire the RCA cables??
Old Sep 2, 2006 | 09:27 PM
Notladstyle's Avatar
King of Ricers
hook the two outputs from the headunit to the 4channel and use the line out to hook into the sub amp?
OR
Change the 4channel to a 2channel mode and use one set for the 4channel amp and the other set for the sub amp.
notladstyle.blogspot.com
Old Sep 2, 2006 | 10:10 PM
P057's Avatar
isuck
I am kinda in the same pickle, i have a 4ch and a monoblock
My headunit only has two outputs as well =[.
What i ended up doing (not because i wanted to) was connecting one set to my 4ch and the other set to my monoblock. Why? because for some crappy reason the inputs on my 4ch (for the rear) introduce awful alternator whine when they're connected.
Good news is it sounds just as good with only one input.
Why?
Most music you listen to is only in stereo, i dont think you have any 4.1 surround sound music cds... i know i dont. =[
Old Sep 3, 2006 | 07:53 AM
well if i hook the output from the 4 ch. to the other amp the speakers that i hav running off of the 4ch buzz. it does the same thing wen i only hook on rca to the 4ch. and the other to the 2ch.??
Old Sep 3, 2006 | 09:05 AM
TBSpyder's Avatar
Originally Posted by P057
Why?
4 channel amps don't have 4 inputs/outputs for surround sound, but taking advantage of the fade and balance controls is a nice feature.
Old Sep 3, 2006 | 01:26 PM
P057's Avatar
isuck
yeah thats what i meant
Old Sep 3, 2006 | 07:13 PM
so any1 have an idea of what my problem is?
also when my engine is on i can hear it through my subs could it be that my power wire isnt insulated right or some1 told me i need resistor type spark plugs?
Old Sep 3, 2006 | 07:18 PM
P057's Avatar
isuck
wow i've never heard subs reproducing engine whine... ouch
You sure you have things grounded good? and there are no loops?
Might want to get your shit checked out if you're having doubts. =S
Old Sep 3, 2006 | 07:28 PM
TBSpyder's Avatar
Does the whine vary when you rev the engine?
I'd first check your sub amp's ground. Make sure it's tight, and if it is, try moving it. Then I'd check your rca's, try disconnecting one channel at a time and see if it still whines. Then try swapping the rca wires completely. If none of that works, it could easily be the amp itself, the rca ouput deal on amps is shit most of the time.
Old Sep 3, 2006 | 07:58 PM
King of Ricers
Just put a floating ground from the RCA shielding on the cable between the amps.
