It's all gone...almost
Old Aug 17, 2006 | 04:56 AM
  #21 (permalink)
66impalass's Avatar
Actually it was a compustar, they didn't unwire it they just stole the brain which means the people that broke in my truck knew where it was, which means they worked on it before. neighbors said my alarm was going off for like 3 min. No one even bothered looking out there window at my truck which sucks
Old Aug 17, 2006 | 07:08 AM
  #22 (permalink)
TBSpyder's Avatar
Originally Posted by NoTLaDStyle
that had to be one shitty alarm if not only did it let them steal everything in the car but also unwire and remove the alarm itself
tell me, was it Pyle brand?
It's really not all that hard to get past an alarm. I use to see it quite often actually. The most effective way of preventing theft I've found, by far, is a stealthy install. If they can't see it, can't get to it, and/or don't know it's there they're most likely not going to attempt to break in in the first place.
Old Aug 17, 2006 | 07:30 AM
  #23 (permalink)
GradeA_TireFryer's Avatar
All American, rice eater!
thats is why i always suggest a pager or 2 way remote to tell you when your alarm is going off - and horn honk is a must - really hard to sleep with a horn going off non-stop
Pirate Customs
Sound, Security & Style..... anything for your ride
Old Aug 17, 2006 | 08:13 AM
  #24 (permalink)
Notladstyle's Avatar
King of Ricers
Oh noes, I just installed a compustar 2way system in Dans car
Let us pray that he hears the alarm going off and brings his baseball bat to yield before they figure out how to pull the alarm.
Yes yes Ive always found it extremely satisfying to use several roles of masing tape as well. Not only is future maitenence near impossible, I doubt even I would recognize the wiring. I also dont prewrap any of the wires (besides the siren) so then when I install it I can bundle door locks with the ignition or whatever wires happen to be near eachother easier.
notladstyle.blogspot.com
Old Aug 17, 2006 | 04:19 PM
  #25 (permalink)
P057's Avatar
isuck
I got the 2-way remote, i can tell when ppl are fucking with mah car.
Though the whole sleeper aspect of it really helps a buttload
Old Aug 18, 2006 | 04:55 AM
  #26 (permalink)
66impalass's Avatar
doesn't help when you can sleep through anything and your neighbors dont care
Security and Remote Start
Up to 6000 feet of Range
This ground-breaking 900MHz Spread Spectrum 50-Channel frequency changing technology was developed by Firstech after spending thousands of hours perfecting the art of radio signal modulation and applying it to vehicle security and remote starts. This technology resulted in one of the most advanced security technologies available for the automobile. These modulation techniques help eliminate interference and allow for more power to transmit than conventional systems.
(Includes 1 two way remote. The one way remote pictured is optional)
Basic Remote Features
Two-way paging remote
Vibration and audible notification
Run-time indicator
Turbo Timer
CompuGlow backlight
Multi-color LCD (liquid crystal display)
Shock sensor on/off through remote
Timer start mode
Passive mode on/off through remote
Valet mode on/off through remote
Uses standard AA 1.5 volt battery
2002 Innovation Award Winner
Basic Alarm/Start Features
Includes dual stage shock sensor
RPS (remote paging system)
External Siren (six-tone)
Super bright blue LED
2-auxillary outputs
Dedicated trunk output
Horn honk output
Includes anti-grind and starter-kill relay
Driver's priority unlock
Ignition controlled door locks
Trunk output
Remote start
Diesel features built-in
Manual transmission compatible
Old Aug 18, 2006 | 12:00 PM
  #27 (permalink)
P057's Avatar
isuck
yeh i have that one except no remote start, i dont really need it. Although window roll down would be really nice...
The range is actually pretty decent. I went about ... hm 1/8th of a mile i guess away from a walmart dalton was in and behind an amscot, he was inside and i think up to the vegetable isle in the super walmart and i think thats the range it died at.
Not too bad.
I cant sleep through anything, i barely sleep at all. Plus i have it on vibrate, attached to me about 20/7 and if not stuck to me its really fkn close to me.
=D.
