FAQ section?
Old Dec 30, 2005 | 10:55 AM
Notladstyle's Avatar
King of Ricers
Originally Posted by djgizmo
I was always under the impression of
1 watt = 1 volt × 1 ampere
X Watts = 12 volts x 20 Amps
240 Watts
I'll start the new FAQ thread this weekend. Be a nice lil project for everyone to contribute to.
thats true but you cant measure the amps power consumption to determine its output power - step up transformers are innefficient and you also lose a lot of power to heat.
To get a real wattage reading take the voltage at the amplifier output while tapped to a 4 or 2ohm coil and divide by this formula:
Volts^2 / Ohms = Watts
Doing that you get the actual power thats being delivered to your sub.
notladstyle.blogspot.com
Old Dec 31, 2005 | 11:05 AM
djgizmo's Avatar
Sound Engineer for Hire
EDIT: re-read voltage at the amp OUTPUT. Yea, but how does one determine a try to determine wattage w/o hooking up a sub (don't want to blow a sub up to find out how many watts the amp can push)
Also, with the formula I stated earlier, it was a maximum theoretical output of an amp. That means with those facts, the amp cannot pull more current (amperes) than its fuses w/o popping them. Therefore the abosolute maximum power output cannot be larger than its input right?
"Your Music, Your Tunes"
Old Dec 31, 2005 | 12:56 PM
King of Ricers
Two 8 ohm 1000watt copper coils from radioshack - drop them in distilled water and have at it. I have managed to shatter 3 or 4 glasses with this method.
Peak current can exceed the fuse rating as automotive and maxi fuses have very leniant tolerances example: a 30 amp blade fuse has +20% @ 5 second / +50% @ 1 second etc..
The fuses dont instantly blow at their rated capacity - Since each manufacturer has its own tolerances it would be very difficult to use that as an accurate gauge.
Old Jan 3, 2006 | 06:08 AM
93ex's Avatar
Just Ledoux it!
Agreed, it's not gospel, but it can put a ballpark number, and it makes for a good time when someone has a 2000 watt amp with a 10 amp fuse in it.
Old Jan 3, 2006 | 09:35 AM
King of Ricers
Old Jan 3, 2006 | 11:06 AM
djgizmo's Avatar
Ahh, makes sense now. Max output can exceed fuse rating for short burts but not for continous power.
Hehe, when I get my amp, I'll try the glass idea. I now know why you're going into electrical engineering.
93ex, you got exactly what I was trying to say...
