engine noise
it haD nothing to do with the amp or the wireing or the grounds, it was the shitty rca's sony uses in the wire harness for the ps2. unhooked it and the noise went away. the lanzar amp pushes alot of poewer but the sq is crap. im still looking for a new/used amp let me know if anyones got a decient one for cheep
That doesn't necessarily mean it's the ps2 rca's. It could also be noise induced from your power converter into the ps2.
Originally Posted by Raymon
You could just insert a GNI ( Ground Noise Isolator between your PS2 and your AUX input.
http://search.ebay.com/ground-noise-...jsZ1QQfromZR40
Originally Posted by integralsgreen
i get alot of engine noise comming out of my speakers while my car is running. it makes a a frequwncy noise that gets higher and lower with my rpms (verry anoying especially with a honda). anyone know what causes this or how i could get rid of it? could it be an issue of not having enough power for everything?
I have two amps and an EQ (with inline power filters on the power wires) all running off the factory head unit and I have no engine noise.
Originally Posted by REV2 8K
What you could try is running whats called a trace ground. Where you run a new ground wire (16 gauge would be fine) from your deck all the way back to your trunk and ground it with the ground for your 4-ch amp. If there is even a 1 volt difference in grounds, you will get engine noise. Make sure the ground for your amp is screwed directly to body metal (ie. trunk floor or floor pan under rear seat, etc.) with the paint scraped away.
CamaroJoe
4
Apr 12, 2004 03:35 PM
Scott
Nov 7, 2002 07:33 AM
