any help with my system
Old Jan 26, 2004 | 07:15 PM
MDIFYTD's Avatar
Uber lurker
It's either a bad power or ground connection with the HU. Check all the connections are tight, clean, good solders etc. If so then you may have to do what Jesse said and run a seperate power straight to the battery. If you do that you'll want to run a ground of the same gauge.
Ill say i go by His and Al's thoery of "Your getting sprayed" Doesnt matter what it is. Grandma in the 1982 LTD is gettin the bottle.
Old Jan 26, 2004 | 07:41 PM
TBSpyder's Avatar
Yeah, I have to agree with Steve...sounds like a loose wire or fuse somewhere. I'd double and triple check all you power and ground wires on your HU.
Old Jan 27, 2004 | 04:50 AM
SSpiro's Avatar
Errare Humanum Est
Originally posted by neondriver
yah. while im driving, it only cuts off for the cd part and not the radio, it doesnt shut off but the minute display stops a second or two then it plays again it does that for all deep bass. the cd doesnt skip i knoe really loud bass can cause that but its not that loud especally because it cant be turned that loud.it never did this until i got these sub's even when i bridged the ampp to 1 sub it did it.
I don't know guys.. sure as hell just sounds like the bass is skipping the deck. I have this exact same problem and does the exact same thing. Also it never does it for the radio?.. Seems kinda obvious to me. You guys are looking into it too deep.
Turn the deck down to a low level (a level in which you could talk to someone sitting next to you) and start the song over and see if it does it.
If it does, then its a power issue or quality of the deck issue.
If it doesn't, then its the bass skipping the deck.
Old Jan 31, 2004 | 04:58 AM
neondriver's Avatar
Default ok
thanks everyone im gonna check everything out this weekend and try everything that you suggest i try
Old Jan 31, 2004 | 04:59 AM
neondriver's Avatar
Default http://members.cardomain.com/neondriver
Old Jan 31, 2004 | 05:14 AM
SSpiro's Avatar
Errare Humanum Est
OK?
Old Jan 31, 2004 | 09:36 AM
  #17 (permalink)
Derek's Avatar
Whitey on the Moon
maybe your amp running your highs after all its legacy...
