Need help ls-vtec build - need help ls-vtec build *see*
Old Nov 13, 2012 | 02:26 PM
LosFiebruElbebo's Avatar
Unhappy Need help ls-vtec build - need help ls-vtec build *see*
Hey tr, i finally finish my ls-vtec swap and droped it in my ek hatch. Everything is connected it's on a p28. Single cam harness. Also built in internals for high compression. I turn it on, but won't rev more than 2k sadly idk wat to do injectors are working perfect also all the sensors, tps,map,ect.
I notice it rev redline wen i use starting fluid but with just normal it won't pass 2k rpm. Please help!
Contact me : 813-802-1429 willing to pay. Maybe some of ya encounter this problem!
Note: My most accurate guess might be the wiring harness since it's from a d-series.
If so i wtb b-series harness that would work with my ls-vtec
Old Nov 13, 2012 | 03:30 PM
eh2Lou's Avatar
is the p28 chipped? any cels? possibly your tps sensor, try swapping throttle bodies.
Old Nov 13, 2012 | 03:35 PM
REVV10k's Avatar
check where the harness plugs into the ecu move wires around mine used to do the same ....or if not might be the ecu seems kinda like in limp mode
Old Nov 13, 2012 | 03:47 PM
HondaHeaven's Avatar
HondaHeaven
You may have a fuel sending issue, check or replace fuel pump. I would'nt rev it to redline with starting fluid if I were you.
Old Nov 13, 2012 | 07:41 PM
No It's not chipped, virgin p28. Idk about the cels explain please,
Already check TPS and already switch trottles bought a skunk 2 70mm
Old Nov 13, 2012 | 07:46 PM
probly, in limp mode I es reading a tread about the same ecu but didn't understand quite. If it is on limp mode what should be done ? The ecu works fine, because I tryed it on another civic and it rev successfuly but in mines won't pass 2k
Old Nov 13, 2012 | 07:50 PM
That's what I thought at first that not enough fuel was coming in, but the pressure on the fuel has pretty good force. I also been thinkin if the distributor is bad but i bought it brand new and the car starts fine it just dosent rev pass 2k
Old Nov 14, 2012 | 09:49 AM
Bump
aznkhmerracernza
Nov 12, 2006 09:26 PM
danny_240sx
Oct 20, 2006 05:33 PM
francocapo
Nov 2, 2005 02:05 PM
