13b tt Fd motor into a Fc wiring questions.
Old Sep 11, 2011 | 10:17 AM
paperchaser08's Avatar
Default 13b tt Fd motor into a Fc wiring questions.
i'm sure there have been plenty of these threads. but i figured i'd post another one just to get some insight.
as far as wiring goes, what all do you need to do/use to have this motor run in a Fc
im not so good at wiring, is there a kit i could buy? whats the simplest route for this swap?
thanks for anybody's help
-Levi
Old Sep 13, 2011 | 05:16 AM
NI_racing's Avatar
Essentially you just need power to the starter, spark at the plugs, and fuel through the injectors to make the engine run in any car. But to do what your asking isnt very hard, lots of people have done it before. It depends alot on what ecu your going to run. If you have just the engine, then the stock connectors should work for most of it minus the TPS as thats different. injector plugs should be the same. The alt connector is different (unless your not going to run the FD alternator). The MAP or MAS is going to be different if your even going to run the stock air metering system for either platform. Im assuming your bolting it to the FC trans? I have heard before that there is a difference between the FC and FD trans as one is a push system and one is a pull and its a slight pain to convert? But i have no experience with that.
The other thing that may be of concern is your turbo manifold and turbo selection. If your going to run the twins, you need to make sure that you have clearance between the twins and the fender, on the passenger side. Some people have issues running the FD manifolds in the FC and some dont. Im not sure why theres a space issue, but you should go ahead and make sure that its all gonna fit nicely before you get ready to drop it in.
Ill scoop up some links on the swap in a lil bit when i get some time to grab em
Tampa Bay Rotary Owners Club Member # 4
PIT KREW
TEAM MEMBER
________________
Team Decep!
you never saw it coming
Old Sep 14, 2011 | 08:07 PM
miataspeed's Avatar
stand alone!! be done with it. fuck the factory system, it will only hinder you.
if you havent been in a small plane its worst, cause your eyes and brain say we are moving and your body says oh no we are not. eyes and brain go asshole we are moving, cant you see? body says fuck you we are not moving at all. so they fight and fight and eventualy your body says, you know what fuck you brain, see if you can stop this!! then you throw up.
Old Sep 15, 2011 | 05:23 AM
NI_racing's Avatar
i agree with ^ but if moneys an issue then you make it work the best you can.
PIT KREW
TEAM MEMBER
________________
Team Decep!
Old Sep 15, 2011 | 07:43 PM
miataspeed's Avatar
if moneys and issue you really are playing with the wrong engine and cars. lol
nskyline85
Nov 13, 2005 02:54 PM
Danielson2881
Jun 20, 2004 10:41 PM
i-h8mytruck
Sep 24, 2002 09:36 AM
