Wiring Questions
Here's the deal, I bought a 95 B18B with ECU, to put it into my 91 DX hatch. I did not get any wiring harness whatsoever. I need to know exactly what to buy( dont want to rig anything) to put this into my hatch.
I know I will need to get the motor harness harness from and OBD1 Integra, but exactly what else do I need wiring wise, everything else I can do and understand. I have looked all over the web trying to find this and have had little luck. Google has failed me. I know to some of you this is so simple, but it's my first swap so your help is appreciated.
Also, if you have done this and work for pizza or mountain do or anything else cheap, the day I drop it in I will feed you and give you all the mountain dew you desire.
Thanx,
ZACH
Thanx,
ZACH
got to convert to MPFI, which i think you'll have to rig, and i thought 92-93 was OBD-1? or is it 94+? prolly be easier to use a obd-0 teg ecu, and harness, if the harness plugs up to all the sensors... otherwise you need to try to find a conversion, i think skunk2 makes one.
El Pendejo Loco
2002 Suzuki Hayabusa
1507 "dry" block
Brocks megaphone
Spencercycle 10" swingarm
MPS auto shifter
Hays convertible clutch
Yea, that about sums it up...
El Pendejo Loco
1507 "dry" block
Brocks megaphone
MPS auto shifter
Guest
Posts: n/a
Thanx,
ZACH
Thanx,
ZACH
resistor box too
El Pendejo Loco
1507 "dry" block
Brocks megaphone
MPS auto shifter
El Pendejo Loco
1507 "dry" block
Brocks megaphone
MPS auto shifter
THERE IS A PLACE IN CAIL. CALLED PLACE RACING THEY MAKE THE HARNESS YOU NEED I THINK ITS AROUND $200 BUT I'M NOT SURE. I LOOKED AT THE 94 LS ACURE AT B&S YESTERDAY I LIVE NEAR THERE IT IS IN MINT COND. EXCEPT THE MOTOR IS BLOWN SO YOU MIGHT WANT TO CHECK IT OUT.
IF YOU CAN'T RACE IT OR TAKE IT TO BED IT'S NOT WORTH HAVING!!!!!!!!!!!!
