Resetting ecu / pulling ecu code ka24de
Old Jun 20, 2011 | 08:33 AM
bikeimports's Avatar
Default Resetting ecu / pulling ecu code ka24de
Found this helpful so:
how to reset the ECU:
"Find the computer(Behind the plastic piece by the passenger foot
Pull it out
Turn your key to the on position
You will see a flathead screw looking bolt on 1 side of the computer. Turn this fully clockwise
Wait at least 2 seconds
Turn it back to fully counterclockwise
This will then show the trouble code - (The check engine light will blink to show this, for instance, blink..blink..blink......blink..blink, will be 32)
After you read the code, you can start the engine
Turn the bolt back to the clockwise position for at least 2 seconds(While running)
Turn it back to the counterclockwise position
Now shut the car off and then start it again, this should of removed the code."
11 Crank Angle Sensor
12 Mass Air Flow Sensor
13 ECT Sensor
14 Vehicle Speed Sensor
16 TCS Signal
21 Ignition Signal Circuit
25 Idle Air Control Valve
22 Fuel Pump Control
31 ECM
32 EGR Function
33 Heated Oxygen Sensor
34 Knock Sensor
35 EGR Temperature Sensor (RH)
41 Intake Air Temperature Sensor
42 Fuel Pump Sensor
43 Throttle Position Sensor
45 Injector Leak
46 Secondary Throttle Sensor
51 Injector Analysis
53 Exhaust Gas Sensor (LH)
54 Signal Circuit From A/T Control Unit To ECM
55 System OK (1990-1995 Q45 only)
65-71 Single Cylinder Or Multiple Cylinder Misfire
72 Three Way catalyst Function
76 Fuel Injection System Function
77 Rear Heated Oxygen Sensor
82 Crankshaft Position Sensor
84 A/T Diagnosis Communication Line
91 Front Heated Oxygen Sensor Heater
103 Park/Neutral Position Switch
105 EGR & Canister Control Solenoid
Old Jun 20, 2011 | 08:57 AM
mewantkouki's Avatar
no
This has already been posted in the sticky section.
Page two of the SR, ca, rb look here first! thread second to last post.
PiNoYcLaSs
Nissan/Infiniti Tech
Oct 2, 2010 08:49 AM
formula69
5
Jun 7, 2004 09:29 PM
96Integ
Nov 14, 2001 05:12 PM
