resetting pcm on LT1?
Old Jun 1, 2004 | 08:31 PM
formula69's Avatar
blowed up
Default resetting pcm on LT1?
how do i do this? pull some fuse somewhere? i dunno but i need to reset mine so if you know how tell me
Originally Posted by 05general lee
im FAT!!!!
Originally Posted by Little Nicky
Scott is my body guard
T.R. $100,000 kill club member #002
Turtle crew member #2
Old Jun 1, 2004 | 08:58 PM
formula69's Avatar
blowed up
cant i just pull my PCM BATT fuse for like 30 secs?
im FAT!!!!
Old Jun 1, 2004 | 09:39 PM
ponchoV8's Avatar
99ProblemsButABitchAin't1
Never heard of pulling the PCM BATT fuse, but it sounds easy enough. You can disconnect the batt. like Mars said, but any set codes will remain and will appear again once the problem occurs, with the same code showing up twice or more on a scanner, so you should have it scanned and delete any codes if you have any. If your car is a '96-up OBD2 model, you can take it to AutoZone where they can scan it for free and delete any codes for you; I just had mine done yesterday when the SES light came on for the air pump, but luckily there is a recall for the air pump on my '97 so off to the dealer I go for some free service.
What is best in life?
"To crush your enemies, see them driven before you, and to hear the lamentation of the women!" -Conan
Old Jun 3, 2004 | 06:03 PM
BlackZ28's Avatar
ppssshsshhhhhhh
battery has to be disconnected for at least 20 minutes.
www.mcgtile.com - Professional Marble and Tile Installation
Racing Integration
Proven Power
Old Jun 7, 2004 | 09:29 PM
formula69's Avatar
blowed up
i have a 94... im having some heating problem.. after my car is running for 10 minutes, every time i hit 5000 rpms my car shitts on its ass and some sensor retards my timing and i lose ALL my power.. its also not pulling quite as hard after it runs for 10 minutes.. any suggestions? someoone said theres a heat sensor in the block that could be bad.. its on the drivers side by the headers.. someone also said there are some sensors on my radiator that could be bad... any suggestions cuz its not the thermostat and i have full coolant and PLENTY of airflow into my radiator.. some of you know ive had this problem for a long time!!
im FAT!!!!
