Resetting ecu / pulling ecu code ka24de
Found this helpful so:
how to reset the ECU: "Find the computer(Behind the plastic piece by the passenger foot Pull it out Turn your key to the on position You will see a flathead screw looking bolt on 1 side of the computer. Turn this fully clockwise Wait at least 2 seconds Turn it back to fully counterclockwise This will then show the trouble code - (The check engine light will blink to show this, for instance, blink..blink..blink......blink..blink, will be 32) After you read the code, you can start the engine Turn the bolt back to the clockwise position for at least 2 seconds(While running) Turn it back to the counterclockwise position Now shut the car off and then start it again, this should of removed the code." 11 Crank Angle Sensor 12 Mass Air Flow Sensor 13 ECT Sensor 14 Vehicle Speed Sensor 16 TCS Signal 21 Ignition Signal Circuit 25 Idle Air Control Valve 22 Fuel Pump Control 31 ECM 32 EGR Function 33 Heated Oxygen Sensor 34 Knock Sensor 35 EGR Temperature Sensor (RH) 41 Intake Air Temperature Sensor 42 Fuel Pump Sensor 43 Throttle Position Sensor 45 Injector Leak 46 Secondary Throttle Sensor 51 Injector Analysis 53 Exhaust Gas Sensor (LH) 54 Signal Circuit From A/T Control Unit To ECM 55 System OK (1990-1995 Q45 only) 65-71 Single Cylinder Or Multiple Cylinder Misfire 72 Three Way catalyst Function 76 Fuel Injection System Function 77 Rear Heated Oxygen Sensor 82 Crankshaft Position Sensor 84 A/T Diagnosis Communication Line 91 Front Heated Oxygen Sensor Heater 103 Park/Neutral Position Switch 105 EGR & Canister Control Solenoid |
This has already been posted in the sticky section.
Page two of the SR, ca, rb look here first! thread second to last post. |
