Pressure in the crank case
Old Feb 6, 2011 | 06:19 PM
patrick sakitis's Avatar
Default Pressure in the crank case
Pressure in the crank case and blowing alot if air out of valve cover tube. Checked compression all the same at 170 across the board. I did a boost leak test was filling crank case with air also a little girgling noise like water but no pressure in the radiator. Wanted to know if anyone would know what might be going on. thanks
btw its turbo
Old Feb 6, 2011 | 06:23 PM
97EJ-6's Avatar
Kiss Mi Ras!!!!!!
thats bad rings what car? and you should explain it more clearly
JumpManPm me for any needs for a Honda/Acura/Evo. From tune ups to motor builds TR "Old Skool DA" Member #91Still Jokie!!!!!!!!!
Old Feb 6, 2011 | 06:27 PM
teg lsv
Old Feb 6, 2011 | 06:35 PM
97EJ-6's Avatar
Kiss Mi Ras!!!!!!
are you in tampa? if so pm me and il give you my number and you can bring it by for me to check it out
Old Feb 7, 2011 | 02:51 PM
nope not in tampa if i was id stop by so your thinking rings any one else thanks
Old Feb 7, 2011 | 06:58 PM
Alex H.'s Avatar
Registered EF driver
If it was rings wouldn't it have bad compression? And smoking?
1991 Honda Civic Hatchback Si complete USDM OEM Honda restoration in the making.
TR "Old Skool EF" Member #208
Cell: 727-452-7280
Old Feb 7, 2011 | 08:07 PM
97EJ-6's Avatar
Kiss Mi Ras!!!!!!
bad compression not nessecarily there are compression rings and oil rings it could be the oil rings
Old Feb 7, 2011 | 08:11 PM
Alex H.'s Avatar
The oil rings are below the compression rings, so if that was the case then the compression rings would have to be bad.
Cell: 727-452-7280
Old Feb 7, 2011 | 08:14 PM
Alex H.'s Avatar
Can it be a possibility that the PCV isn't working correctly? Doesn't that basically suck out all the fumes and gases out of the crank case, including air?
Cell: 727-452-7280
Old Feb 7, 2011 | 08:23 PM
97EJ-6's Avatar
Kiss Mi Ras!!!!!!
good point this could be true
