Thread seal
Old Sep 3, 2006 | 08:18 AM
Whaazup17's Avatar
Default Thread seal
Ok. HAh This is my first time working on almost any car so work with me here
I took the thermostat housing off and removed the gasket. Now on the housing there was a threaded sensor with two wires connecting to it. I took this out (shouldn't of done it). Now I don't have a seal on the car. Should I purchase locktite or something or could I use the same stuff that you use to seal the air lines?
Would the same stuff you use for the air lines work?
Old Sep 3, 2006 | 08:28 AM
Stewart Scott's Avatar
"Now I only have two"
yeah don't use teflon tape it usually heats up and goes away or loses its hold especially on water stuff. tried it myself and learned the hard way. Use a thread sealer that is designed for radiator/water stuff or use J/B weld if you never plan on taking it out again. Remember DON'T use J/B weld if you want to remove or service it in the future. go to an autoparts store and get the right stuff.
God bless America!
God bless our troops!
God bless the GOP!
Old Sep 3, 2006 | 08:32 AM
Whaazup17's Avatar
dang.. this sucks... I wasn't expecting to have to get it hah... I guess I am going to have to hoof it ... So get what locktite for this or something?
Old Sep 3, 2006 | 09:23 AM
Whaazup17's Avatar
Originally Posted by Mars_302
I never had any issues with Teflon tape on threaded stuff for coolant, just make sure you wrap it at least 3x times.
oh yea? THis is the part... It looked like the previous owner put teflon tape on it when he installed it
what is this part anyway?
Old Sep 3, 2006 | 10:46 AM
DrDirt's Avatar
Team Geritol Racing
It's an engine coolant temp sensor.
YO! Barry! You LOST!
Old Sep 3, 2006 | 11:00 AM
$hawn's Avatar
lives in a glass house
yep. and liquid teflon works great to seal the threads.
Originally Posted by cochese
Focus on getting that piece shit down the track, stop posting stories.
Old Sep 3, 2006 | 11:59 AM
Whaazup17's Avatar
looks the previous owner added a switch for a fan relay or something, there is no sensor in the tstat housing
well I do have an electric fan when you turn the key over (no ignition) the fan turns on..
And about my sealing up. I put back the t-stat housing and filled up with water to see if I have leaks and NOOO it is leaking by the t-stat housing... I am soo pissed off right now.. ... It is probably the gasket or something stuck on something.. I really had a HARD time getting that housing on!
Old Sep 3, 2006 | 12:22 PM
Whaazup17's Avatar
What about sealant around the gasket?
