Sponsored by: CARiD
go turbo or ls/vtec
Old Mar 17, 2005 | 06:26 AM
gen2teg's Avatar
Default go turbo or ls/vtec
im not sure if i should go turbo or ls/vtec on my 90 acura integra le i have the block for the ls/vtec swap just need to find the dohc vtec head.... dunno which is better.....
Old Mar 17, 2005 | 01:25 PM
DANGERANGER's Avatar
Shop Bitch
BOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOST IT!!!!!!!!!!!!!!!!!!
More power cheaper parts.
Frank
Enhanced Concepts
727-638-4667
Old Mar 17, 2005 | 03:31 PM
gen2teg's Avatar
what r the pros to a turbo vs. the ls/vtec
Old Mar 18, 2005 | 04:14 AM
03gti1.8t's Avatar
got torque?
a turbo will make way more power then just the swap. you should do the ls swap and turbo that. ls motors produce good TQ numbers when boosted. this one guy on TR has a turbo charged 94 ls teg and he just had it dynoed a few months ago and produced some nice numbers. i think his user name is 94lsteg or something.
[+]H&R cup kit[+]Neuspeed sways and front tie bar[+]Forge 007p[+]3" Forced-Motion turbo-back[+]Injen CAI[+]ECS Dog Bone mounts and STG 1 clutch/flywheel kit[+]Audi TT short shifter[+]REVO 4bar cai & turbo-back file w/ sps 3[+]SAMCO TIP[+]NGK Bk7eix[+]17" RS 4 Replicas[+]VDO[+]42DD A-pillar pod and clear corners[+]
anyone need gmail invites? pm me.
Old Mar 18, 2005 | 05:08 AM
Rich's Avatar
Old School.
Do both, case closed.
You may know who we are, but we KNOW who you are.
Old Mar 18, 2005 | 05:10 AM
gen2teg's Avatar
ok thanks that helps bout the swap problem now where could i find the head and all the turbo stuff for cheap cuz im still in school
Old Mar 18, 2005 | 08:18 AM
Z32twinturbo's Avatar
Two Turbos Blow You Good
nether, sr20det it!!!!!!!!!!!!!!!!
Old Mar 18, 2005 | 08:43 AM
gen2teg's Avatar
explain y that is better
Old Mar 24, 2005 | 07:44 PM
Josiah's Avatar
Peon on steroids!
frankly, I think vtec is overrated, sure its neat...but just a set of big cams in a non vtec DOHC is just as good...sure you geta rougher idle, but so what?just turn up the idle a bit, boost is where its at in any 4 cylinder, most 6 cylinders, and always fun on an 8
