Found boost/fuel cut on the 1JZ last night. Sell me a MK4 MAP.
Old Oct 18, 2004 | 05:19 AM
flubyux2's Avatar
Elitist Supra Asshole :)
Default Found boost/fuel cut on the 1JZ last night. Sell me a MK4 MAP.
Yea, Kelly was riding out 2nd gear and all of a sudden, it felt like speed cut... only at 50mph. At first, she thought it was rev limiter. but i noticed the speed and im like "uhm, no... 2nd gear tach's out to over 70mph... Plus the check engine light came on and then went off" soooo... we found fuel cut on a STOCKness 1JZGTE... NO modifications except HKS SMF intake and open Stock downpipe... Nothing else. guess we will need an upgrade ECU sooner than we thought. shit, if its fuel cutting on a STOCK down pipe, i can only imagine what its going to be like when i make a 3" downpipe for it. i still cant beleive that its boosting that high w/o any boost control and stock exhaust components. that is too crazy. guess i need to hook up the SAFC and a MKIV Map or something. i can only wonder how its going to run w/ the APU equipment.
Old Oct 18, 2004 | 11:46 AM
Orion ZyGarian's Avatar
7M 2JZ bird in pear tree
Andy needs to come in here...he has a full 3" exhaust. Cant be boost cut because thats at 28 psi
I'd suggest a GM 3" MAF, then a MAFT. Thats what I'm going to do. Also, check SF 1JZ section
ASE: Brakes
Old Oct 18, 2004 | 12:52 PM
psifactor's Avatar
Hello
yes it was boost cut the ecu is VERY restrictive. I think anything above 18psi and the ecu will cut out.
why exactly do you recommend a maf? I'm completely confused here.
Heavy car with a 2.5L
Old Oct 18, 2004 | 01:23 PM
williamb82's Avatar
grease monkey!
the maft is for the 7mgte, he has a 1jzgte, it wont work on the 1j.
william
Old Oct 18, 2004 | 01:27 PM
psifactor's Avatar
Hello
I'm pretty curious why you would recommend any mas and also say the ecu will not cut out till 28psi...makes no sense.
Old Oct 18, 2004 | 01:31 PM
j30a1t's Avatar
Single > Twins
28psi ... right ...
thats why its 14psi on a 7m and 17psi on a 2j
Originally hollered by PoppaSmurf: Hey!!! Driver!!! Your Face!!!
TheSh0w50h: I am teh badass assed roll racer evar, I eat mkIV's for lunch.
Originally posted by JuicedSS262
No longer have the stomach for clubbing baby seals.
Those sad eye's got to me.
Old Oct 18, 2004 | 01:35 PM
Originally posted by j30a1t
28psi ... right ...
Joke from LOOOONG time ago on i-Supra. Some dumbass skyrocketed the boost to 28 psi and was wondering WHY there was boost cut...
EDIT: Heres the link. Enjoy
http://i-supra.com/eve/ubb.x?a=tpc&s...61#50510527061
ASE: Brakes
Old Oct 18, 2004 | 03:01 PM
psifactor's Avatar
Hello
just because it spiked once.......The ecu will no hold over 18lbs. so i need a mines or something similar.
So why should I get the GM Maf?
Old Oct 18, 2004 | 03:29 PM
williamb82's Avatar
grease monkey!
the maft allows you to turn off fuel cut on the 7m. it doesnt work on the 1jz though.
Old Oct 18, 2004 | 03:50 PM
joeyk's Avatar
THE MAN
I wouldnt worry too much about the ecu , you need to worry about them there turbos....
and yes you should get a gm maf for a christmas gift for chris
