2002 vw jetta
Old Sep 3, 2002 | 07:44 PM
chet's Avatar
All Aboard
Default 2002 vw jetta
ok, this is for a friend of mine...
she just ordered a new jetta 1.8t and wants to get an exhaust for it.
what kind you do recommend?
and also, what kind of suspension should she get...i'm assuming neuspeed?
Old Sep 17, 2002 | 06:50 PM
VR6M80's Avatar
I agree with the exhaust recommendation however I recommend coilover suspention over all. Coilovers are more expensive, but have proven to be a trillion times better time and time again.
Fear not, I gobble cock
swallow too
Old Oct 4, 2002 | 05:05 AM
jim wilson's Avatar
Does she want to go fast, make noise, or both? I would just do a 3"DP for about $250, that should give her about 5hp stock or 10hp if chipped. The Cat is another $150, if you can't find someone to install it I can do it for $50 on the DP or $75 on the cat & DP. If she wants HP she should get a chip which will take her from 180hp 174ft/lb to 210hp 250ft/lb. I do these also and they run $350 installed.
Old Oct 4, 2002 | 06:20 AM
chet's Avatar
All Aboard
well, the car itself was ordered a month and a half ago and it still hasn't arrived. it looks like vw has had a lot of orders for these cars and she's getting tired of waiting. but a chip is definitely something she's interested in...
and jim, how many psi does the chip allow you to run at? or what is the increase over stock...
thanks, chet.
Old Oct 6, 2002 | 05:01 AM
RoadRacer's Avatar
Turn 7 at Sebring
I am pretty sure the chip will bring the boost to 1.0 bar or 14.7 lbs + or - a little. I am not sure of the stock boost.....probably 8 or 9 lbs.
Patrick
Old Oct 6, 2002 | 02:28 PM
chet's Avatar
All Aboard
is anything else needed with the chip? ie larger fuel injectors or a new fuel pump?
thanks, chet.
Old Oct 6, 2002 | 09:10 PM
b16aRacer's Avatar
Moon Equipped
thanks, chet.
generally no. plug and play. although that is unless the chip mfg. reccomends something.
'00 FBP Si
Sebring rule in effect
