HELP!!!! No Throttle Response ....
Old Aug 11, 2010 | 08:39 AM
Garrett's Avatar
pfft.....
Default HELP!!!! No Throttle Response ....
okay heres my issue...
i have a 2002 VW GTI with the motor, trans, ecu from a 2004.5 Jetta GLI. Its got an APR Stage 3+ BT kit. There are other mods but nothing that pertains to this issue.
the car ran fine the other day no problems what so ever. i goto get into the car last night it starts fine but the RPM's hold at 1200 rather then the normal 800. When i press the gas there is no response at all it acts like im not even pressing on the pedal at all.
scanned with vag-com and heres what i got.
Originally Posted by VAG-COM
VAG-COM Version: Release 409.1-S
Chassis Type: 1J - VW G/J/B Mk4
Scan: 01,02,03,08,16,15,17,19,22,35,46,56
Address 01: Engine
Controller: 06A 906 032 HS
Component: 1.8L R4/5VT G07 0008
Coding: 07500
Shop #: WSC 00000
9BWDE61J924000562 VWZ7Z0A3896438
4 Faults Found:
18039 - Accelerator Position Sensor (G79): Signal too High
P1631 - 35-00 - -
18042 - Accelerator Position Sensor 2 (G185): Signal too High
P1634 - 35-00 - -
16487 - Mass Air Flow Sensor (G70): Signal too High
P0103 - 35-10 - - - Intermittent
17524 - Oxygen (Lambda) Sensor Heating: B1 S1: Open Circuit
P1116 - 35-10 - - - Intermittent
Readiness: 0110 1101
Address 03: ABS Brakes
Controller: 1C0 907 379 D
Component: ASR FRONT MK60 0103
Coding: 0021505
Shop #: WSC 00000
1 Fault Found:
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
Skipping Address 15-Airbags
Address 17: Instruments
Controller: 1J0 920 906 J
Component: KOMBI+WEGFAHRSP VDO V02
Coding: 07232
Shop #: WSC 00000
No fault code found.
Address 19: CAN Gateway
Controller: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 00000
Address 46: Central Conv.
Controller: 1C0 959 799 C
Component: 1J Komfortgerát HLO 0003
Coding: 00064
Shop #: WSC 00000
1 Fault Found:
01179 - Incorrect Key Programming
35-00 - -
End --------------------------------------------------------------------------------------------------
bad pedal assembly?
anyone got a clue?
Old Aug 11, 2010 | 08:49 AM
Garrett's Avatar
pfft.....
i havent had any time today to check the wiring with a multimeter but will get to it later today...
Old Aug 11, 2010 | 08:50 AM
pipe7284's Avatar
check the connections around the throttle body and see that all the plugs are in place, maybe it was loose enough to fall off by itself.
98 Audi A4 built 1.9 gt30r SOLD
99 Audi A4 1.8t SOLD
00 Audi Silver S4 stg 2 SOLD
97 6 bolt swap 2.3 stroker 2g eclipse GSX SOLD
00 Audi Santorin S4 stg 2
04 Chevy Trailblazer DD
Old Aug 11, 2010 | 08:54 AM
Garrett's Avatar
pfft.....
thats what i thought too... so i removed the TB this morning cleaned it and put it back in.
did a throttle body alignment too and i could hear it clicking like it normally does so i'm assuming it worked correctly.
Old Sep 1, 2010 | 04:37 AM
Kastan1234's Avatar
Vw Street King..
could be a couple things first try unplugging maf, and starting car see if it responds..,ill have to see to fix..
