The Symptoms
Old Feb 16, 2010 | 10:26 AM
korito727's Avatar
Whips Come From Japan
Default The Symptoms
soo i thought my car had bad valve seals. its a mk2 16v.. as far as i know its all stock but my point is it seems like its running rich or something. because it smokes if i romp it or at start off. another person told me it could be a vacume problem. the motor doesnt smoke alot unless i dump the gas and ride it over 4k. it seems almost like it dumps a bunch of gas into the motor and has to burn the extra off. (if it were runnin rich) i just figured id ask and see if anyone has some input. it not really a big deal. the smoke also smells like gas not oil and it doesnt eat oil.. the motor doesnt seem to get hot, i check the temp gage in my cluster (which works) and idk im just not really sure and anything would help thanks
DIE WITH STYLE
£ THEORY87 ¥
Old Feb 16, 2010 | 02:31 PM
korito727's Avatar
25 views and nobody has anything to say? not even a fuck you buy somethin else? lmao
DIE WITH STYLE
£ THEORY87 ¥
Old Feb 16, 2010 | 02:47 PM
chippedabone's Avatar
sorry. lol. dont know shit about cars, read to be enlightened....hope it gets fixed bro
Old Feb 16, 2010 | 03:00 PM
korito727's Avatar
lol thanks.. ill lerk vortex
DIE WITH STYLE
£ THEORY87 ¥
Old Feb 16, 2010 | 03:12 PM
im doin the same for a tranny....nothin for sale. FUUU
Old Feb 17, 2010 | 05:52 AM
jettahead99's Avatar
mk2's are a bitch to own, hope that helps lol
Originally Posted by SayWhaa?
shut your mouth.
Originally Posted by rotarykidd
i wont 'till you fuck it.
Old Feb 17, 2010 | 07:03 AM
Ether811's Avatar
Lead Farmer
the 16vs are CIS, not regular EFI, your ECU does not control fuel output like later EFI vws. your fuel pressure regulator is built in to your mechanical fuel distributor and is possible that it is bad. i've seen it before, had the same kinda problem in the 16v that i used to have, replaced the fuel distributor and it was fine. kind of expensive though so do some more research before you go spending money. hope that helps
Old Feb 17, 2010 | 07:30 AM
korito727's Avatar
Yea thanks for the input jettahead lmao. But hmm that actually sounds kind of right to me. I mean i guess I'll have to look at it after doin some research. Would it be easier to just update the fuel system? Idk prices and stuff for this so idk what's better.
DIE WITH STYLE
£ THEORY87 ¥
Old Feb 17, 2010 | 08:32 AM
Ether811's Avatar
Lead Farmer
this might help if you decide to do a conversion
http://forums.vwvortex.com/zerothread?id=1648969
Old Feb 17, 2010 | 11:29 AM
korito727's Avatar
Thanks dude. I'm gunna need to find the problem and then weigh my options
DIE WITH STYLE
£ THEORY87 ¥
