pls read need help!!!!!!!!
Old Oct 13, 2009 | 08:17 AM
hmmracing's Avatar
dabeetereater
ignition switch, and being a 90 it might be digi ??, could be the transfer pump in the tank,
are the plug wires on right and dubble check make sure the distributor is timed right,
EuroRat #2+#3
"YEA THOUGH I ROLL THROUGH THE VALLEY OF THE SHADOW OF RICE, I WILL FEAR NO TURBO FOR DISPLACEMENT AND TORQUE ART WITH ME... MY RODS AND MY PISTONS THEY COMFORT ME.."
bought not broken!!!
member #2
"having a big turbo is like having a big dick; it's not immediately obvious to everyone, but you have to just rest assured that when it comes time to put it to use, you won't need to explain a whole lot afterwards"
Old Oct 13, 2009 | 06:52 PM
Garrett's Avatar
pfft.....
1.8t's dont have plug wires or a distributor.
do you have access to a VAG-COM or at least a OBDII scanner?
Old Oct 13, 2009 | 07:01 PM
hmmracing's Avatar
dabeetereater
umm the dude is talking bout a 90 gti those did not come with 1.8T's and it does not say anything bout a swap so im gonna assume its got wires and a dist.
EuroRat #2+#3
member #2
Old Oct 20, 2009 | 06:15 PM
mech7777's Avatar
Broken... I can fix it!
Post
1990 golf gti knock sensor.
http://www.autozone.com/autozone/catalog/parts/partsShelf.jsp?displayName=Knock+Sensor&currentPag e=1&categoryDisplayName=Engine+Management&navValue =15900126&itemId=126-0&parentId=59-0
Most likely mass air sensor.
AutoZone.com | Vehicle Selection | Year
The mass air flow sensor on this car is more like a swinging door. At the top of the unit there is a carbon, half moon shaped, pad that the brush picks up how much air is flowing into your engine. If it is worn out it will not start at all. On my 89 golf i had the same problem you are having and that was what it was. Also check to make sure it is plugged in. sometimes it looks connected but for one reason or another the pins and sockets do not connecting inside the connector itself. Let me know how this works out for you OK.
email me if you need at: jayfroelich@gmail.com
[HR][/HR]The funniest thing about this particular signature is that by the time you realize it doesn't say anything it's to late to stop reading it.
2014 Sc10n FRS 10-Series
#655 of 2500
