Audi 1.8t - Boost presure issue?
So... my check engine light has been coming on intermittently and the turbo turns off sporadically. It seams to engage random while the light is on.
I plugged my laptop into it and pulled these codes:
17956 - Boost Pressure Regulation Valve (N75): Open Circuit
P1548 - 35-10 - - - Intermittent
17536 - Fuel Trim; Bank 1 (Mult): System too Lean
P1128 - 35-10 - - - Intermittent
I do have some octane booster in the tank, but I've never had a problem with it before. Without it, the motor seem to knock and will not exceed about 4500 rpm.
What do I do to fix the code and make it run correctly? I dunno a whole lot about Audi engines or turbos, but I'm mechanically inclined.
I'm going to look for leaks first, cause the OEM valve is $100. I'm thinking about this one instead of OEM...
ECS Tuning::engine::1.8T/2.7T::RACE N75 Valve
Anyone know if there's an easy of telling if I have a 180hp or 225hp motor? I was told by someone at the dealer that it is a 225, but I'm not sure if he knows what he's talking about. The stock chip has been adjusted to the highest boost it will allow, so i can't really tell by driving it.
That's what I thought, but I was told by an audi mechanic that that's not true. I've also read that the 180's have a single intercooler in the wheel well... The 225's supposedly have two intercoolers. Mine is fairly large and spans the entire front opening (center).
