MK2 Problem.. please help!
Old Feb 7, 2008 | 03:00 PM
BisquitMan's Avatar
Salad Tosser
Originally Posted by RB240Mike
Yes, but also when you give the car gas i neutral with your foot off the clutch it will want to die.
Well your car is CIS, which I hate and will never own, but check the following:
Airflow plate
Idle Stabilizer Valve/control valve
vacuum leaks
Good luck.
Old Feb 7, 2008 | 07:13 PM
elitist's Avatar
TR Balla Donor Supreme
alright, thanks alot I appreciate it I'll check those in the mornin.
Old Feb 8, 2008 | 08:00 PM
das_uber_hase's Avatar
to make it more clerical, does it stall when you let off the clutch in neutral? in the least, can it idle. if it can, that may rule out fuel.
it's either fuel or air, cis kinda takes what it wants unless it's a bad pump, filter, or injectors.
giving the car gas in neutral makes me think that there is some sort of vacuum leak that is allowing too much air to bypass the flow plate.
check all your vacuum lines after the flow plate. the only remedies i can think of at the moment are a general vacuum leak, faulty lines to the isv, a faulty isv, or a bad idle air bypass screw.
Old Feb 10, 2008 | 06:21 AM
elitist's Avatar
"to make it more clerical, does it stall when you let off the clutch in neutral?"
yes, I didnt see any loose vaccum lines, but how would ^ be a vaccum leak? I dunno the whole car is just pissing me off.
Old Feb 10, 2008 | 06:49 PM
elitist's Avatar
Fixed it! It was just a bad ground.. wierd
