vw beetle problem
my girlfriends 1999 beetle's check engine light keeps coming on. we brought it to a mechanic twice. the first time they said it was probably the back o2 sensor, so we replaced it. that wasn't the problem. the second time they put some fuel injector cleaner in it and we also had given it an oil change. that also did not work. the car seems to run like normal, the light just keeps coming on. if anyone knows what it might be please let me know. thanks
There is so many things it could be... I would take it somewhere else other than your mechanic just to get another read on it. Ive had an issue with mechanic cuz his machine overlooked small repairs. So in your case it might be the same as mine. Again its hard to tell what it is unless you post some codes up here.
If you're not cracking oil pans your not low
i dont know the code, but the mechanic's machine said it was running lean in bank 1. whatever that means. forgot to post that lol sorry. if nobody knows what that means I'll take it to autozone to see if i can get a code.
