vr6 ????
i got a 96 jetta vr6 and i dont know that much about the specs of my stock engine.. im plannin on turbo'in it soon and i want to know wut kind of injectors to run and stuff like that?? or wut is the most can i leave stock and how many psi's can i run??? thnx for any help
You will need high impedance top feed injectors. For 6 cyl engines the cc's will equal the supported hp at 43 psi of fuel pressure, so 315 cc injectors will support 315 hp
Your stock injectors with added fuel pressure should support 250hp without a problem. I would look at how much hp you can run instead of how much psi you can run.
Patrick -
Patrick -
Fenders, headlights, grill, hood.
And to answer your other post, you can leave everything stock and turbo it, but you will ruin you motor doing so. If you want to do it cheap, it won't last long and you will have a bunch of problems.
I already told you, 10 psi is about the limit with the stock headgasket. The motor will be fine if it is maintained and the car is properly tuned after being turbo. If you try to cut corners it won't run properly and the motor will fail.
