Cooling problem on a MKIII Jetta
if you get to clean it all out, consider running Evan's waterless coolant... it has a boiling point past 350deg F and fills in the air pockets caused by water turning to steam. That'll actually promote better cooling since it's using the same principle as waterwetter, but with 100% propylene glycol.
Mk2 vr6t chirpin' sixth...
