boost gauge help
Old Jun 3, 2006 | 06:20 AM
3drwhore's Avatar
Pending....
Originally Posted by boostedOne
well, it dont matter which wires on the light you hook up to ground, but one has to be grounded. Make sure the place you are grounding it is actually a ground. Theres lots of metal peices in the dash that dont actually get grounded.
You only have two wires on the dimmer IIRC... if the light is grounded and the bulb is good, either one will turn on the lights when the lights are turned on. Just one wont dim. So if you dont have anything turning on, chances are its not your power source.
thanks man. all of this electrical stuff gets me every time
I think I am going to go out right now and finish it up.
Old Jun 3, 2006 | 11:51 AM
SkwervE's Avatar
realer than most
man it doesnt go to the light switch just the dimmer switch..the dimmer is hooked up to your dash lights so the light on your boost guage will dim too...
Old Jun 3, 2006 | 01:49 PM
3drwhore's Avatar
Pending....
actually it did go to the light switch. thanks.
Old Jun 3, 2006 | 02:24 PM
SkwervE's Avatar
realer than most
when i ran my friends i just ran it to the dimmer switch..
