wire harness help...
Old Mar 9, 2006 | 02:53 PM
f22boi813rd's Avatar
Default wire harness help...
i was wondering if anyone knew where i could buy a cheap engine wire harness or if anyone had one for sale for a 96 vw jetta vr6??? thnx for any info...
Old Mar 9, 2006 | 04:08 PM
mrnicejetta's Avatar
farfromügen
whoah...sorry guy. VR6 anything last about 15mins in a junkyard. You're best bet is going to be ebay or vwfixx.com classifieds. Now also, a 96 VR6 is going to be OBDII, it is probably going to be cheaper, and definitely more hp to look for a 93-95 VR6 harness and ecu(OBDI). Hope that helps.
Der schnellste mann im langsamsten auto
Old Mar 9, 2006 | 04:16 PM
BisquitMan's Avatar
Salad Tosser
Where do you get more horsepower from?? Pretty much anything for a 12v is the same, be smart and just stick with OBD2. Go on the vortex, you can probably find a harness for cheap on there.
Old Mar 9, 2006 | 07:46 PM
farfromügen
I've always seen more hp gains in chipping OBDI VR's than OBDII.
Old Mar 10, 2006 | 02:15 PM
BisquitMan's Avatar
Salad Tosser
Any 12v VR6 will see minimals gains with a chip, regardless of it being OBD1 or OBD2. What do you consider more gains, like .05 hp??
Show me proof, has to be the same dyno, same day, no other mods, only chipped.
Old Mar 10, 2006 | 09:34 PM
das_uber_hase's Avatar
as bisquit said, vwvortex.com. as for more hp on obdI.... could you explain? i am open to learning with a reasonable response.
Old Mar 15, 2006 | 02:14 PM
Caan's Avatar
raising the standard
I think he's referring to the obd1's potential rather than swap for swap gains (in any).
Mk2 vr6t chirpin' sixth...
Old Mar 16, 2006 | 04:48 AM
Matt K's Avatar
im guessing the potential comes from simpler wiring?
aka soflturbo on vwfixx
Old Mar 16, 2006 | 02:00 PM
BisquitMan's Avatar
Salad Tosser
Don't think it matters, all the big boys run standalone.
