wire harness help...
Old Mar 17, 2006 | 06:13 AM
Caan's Avatar
raising the standard
You guys are forgetting that obd1 blocks came with oil squirters. They shoot directly under the pistons and are perfect for turbo apps. Also, all the older 4 bangers (9a, pre 94, PL, PG, etc..) all came with forged cranks rather than cast. That is where the potential hides. As for datalogging with Tec3.... i've never worked with an obd2 ford setup, but the TEC3 unit in my heap doesn't have the best logging. Though, as long as i can see my A/F vs Timing then i'm pretty content with it ... just want more !
Mk2 vr6t chirpin' sixth...
Old Mar 17, 2006 | 09:00 AM
BisquitMan's Avatar
Salad Tosser
Nobody is talking about the OBD1 motor. He was asking about the wire harness.
Old Mar 17, 2006 | 10:00 AM
mrnicejetta's Avatar
farfromügen
I tried to stay away from this thread, but the urge is just too powerful. Why do people keep bringing up Ford OBDII? Do you think anyone would put a Ford engine management system in to a VW for a VW motor? Why even bother mentioning it? Also, I'm not going to waste my time trying to find back to back dyno charts showing OBDI vs. OBDII VR 12v's.
Der schnellste mann im langsamsten auto
Old Mar 17, 2006 | 04:52 PM
farfromügen
Actually, it does make me glad. Now I have learned something new. I did know that there was hardly a difference between a large amount of chrysler and vw 4 cyl. cranks, but did not know that a ford obdII management system was applicable. Cool! Glad it's workin out. On a side note with my personal opinion, I would prefer to go with something like Tec3(don't like the $2k tag) or Digifant when I put the lysholm on. I would like to keep as much OEM as possible, but I would also like to unleash the most amount of hp/tq possible. What are your thoughts? My plan is to run a 95.5 crank, with 83.5 or 84.5 pistons and the lysholm at 22psi. I was planning on running the digi off a G60 and a custom GIAC chip for the increased displacement and boost. Lysholm 16v's are sweet!
Old Mar 18, 2006 | 02:06 PM
  #18 (permalink)
Caan's Avatar
Correct me if i'm wrong, but ford components have bosch roots... right? I mean, i use a mustang o2 sensor to tune my vrt
